Question about Sony Ericsson S500i Cellular Phone
How do you change the message settings so you can write messages easier without it autowriting?
  • 2,069 Answers
Go to messages, >new message, >click on more,> writing options>dictionary> off
thats it.
Posted on Feb 02, 2010
Message when accessing Firefox: your media player is out of date. click here to update now. Ability to do latter not available, message has to do with get credit score.
If you want to update your media player, it's always best to do so directly from the website of the company that makes it, even if they give you push messages saying 'an update is available.' Auto updates can be easier to deal with, but you keep more control if you set the apps to inform you when updates are available and let you run them. Unfortunately, even some large companies will bundle the updates with all sorts of spamware and browser adjustments that change your preferences. Java, for instance, can be exasperating to update without about 37 opportunities to change your default browser and opening page to something like Ask.com.
In any event, you should not have to deal with being pinged for personal info in exchange for your credit score. Your best bet is to cancel any pending or 'failed' update. then go to the webpage for the media player maker and see what is available there.
Good Luck!
Nov 24, 2015 | Cars & Trucks
Samsung A501 Mobile
hi there,
did the problem occur also at when you try to compose for a new message, & may i know if you can still recieve a text messages...?
thank you
May 27, 2008 | Cell Phones
Our company uses the Panasonic KX-T7730 phone system. When I change the answering message, it is immediately followed by an outdated message. Changing the message works, but the old message still fo
When we set up a Panasonic voice mail system, you have a menu that plays. Usually, there is a Company Greeting, then a Custom Greeting. They are changed from mailbox 998 option 5 then 1 or 3 depending on which greeting you want to change.
Of course, you may not have a TVA or TVx voice mail system, but I'm guessing that's what you have. In all cases, the Company greeting plays in front of the Custom greeting. By default in a TVA it's probably both greetings 1. You can log into the system and play them without changing them to verify what's where.
Carl
Feb 10, 2012 | Panasonic KX-T7730 Corded Phone
Reset after oil change
AnswerEasy get an oil change at a garage and have them erase the code or do the oil change your self and then disconnect the neg battary terminal. Easier AnswerOn the console, where the oil change light is on, scroll through the items until you get to oil life. Once at oil life, hold the reset button and it will say Engin oil new? Press reset again and this should set you oil life back to 100% without needing to disconnect your battery
Complete Answer
1- Turn on the ignition without starting the car
2- You will get warning messages on the display (including the "change oil soon" or "oil change required" message) press reset for each warning till you get the Odometer displayed.
3- press the setup button until "press reset for system check" appears
4- hit the reset button (need to do this fairly quickly, if you end up back at the odometer go back to step 3)
5- the system will scroll through the different things that are wrong that it has detected, you should go to "oil life XX%, Hold Rest New" message first if nothing else more major has been detected. When on this message hold the reset down unit you get the message "if new oil hold reset".
6 - hold the reset down till the message "oil life set to 100%" appears (note have seen different wording in some models)
7 - system should scroll through any remaining messages and then return to the odometer reading
Switch the car off and on and confirm that the message does not reappear. Have seen some instances where will not reset, if so take to your dealer.
Read more: http://wiki.answers.com/Q/How_do_you_reset_the_'Change_Oil_Soon'_light_in_a_2002_Ford_Explorer_or_Mercury_Mountaineer#ixzz1GbI0wIQ9
Mar 14, 2011 | 2004 Mercury Mountaineer
Cannot figure out to set answering machine on my vtech, I recevied as gift.
Turn on the answering machine by pressing the on/off button on the base. Set the time and date by pressing the Time/Set button (to the right of the menu button) and pressing Change until the correct day or time is heard. Then press Time/Set again.
To record a message, press Menu until you hear "Set Outgoing Message", then press Record and speak the message (include the mailbox info if you are using them). Press any Play/Stop button to end the message.
Set the various features by pressing Menu to access each one, then press Change to change the setting. Press Time/Set to lock in the change and press Menu to change the next feature. Press a Play/Stop key to leave the menu.
The most important one is "Set Announce Only" to Off for callers to leave a message.
All messages will go into Mailbox 1 unless the caller indicates a different mailbox. Press the Mailbox button to hear new messages if the mailbox has a mix of new and old messages. Press the button a second time to hear all messages. Skip/Quick lets you advance to the next message and Repeat/Slow will let you hear a message again.
Press Vol (up) to adjust the base speaker volume higher during playback.
In the menu, the first option lets you set the two digit security code to access the messages when you call in from another phone. When calling press # followed by 1, 2, or 3 to access the desired mailbox. Press #4 to repeat a message. #5 to skip. Press *0 to end the remote call.
For the full manual, see: http://www.vtechphones.com/vtechphones/index.cfm/support/manuals/ and scroll down to 5866.
I hope this helps.
(all this assumes the base is on (connected to power) and connected to a good phone line. Without power it will not work at all. I test phone lines for dial tone with an old corded phone.)
Sep 25, 2010 | Vtech i5866 Cordless Phone
When I go to send the picture in a text message a box comes up and says the I need to enable my mobile settings I have tried to change everything in my mobile settings and get the same message every time.
Once you dump a picture inside a text message that becomes picture message or mms. Hence, you can't directly send the mms through your mobile without getting settings from your service provider call your service provider and ask them to send mms settings to you and then you can send picture messages. Caution mms messages are costlier than text messages.
Jun 13, 2010 | Cell Phones
How do i reset the settings so that the default message is SMS
Changing your text message
settings
Your KC550 message settings are predefined so that you can send messages immediately. If you would like to change the settings, you
can do this using the Settings options.
Press Menu, select Messaging, then choose
Settings and Text message. You can make
changes to:
Message types - Convert your text into
Voice, Fax, Paging, X.400, Email or ERMES.
Validity period - Choose how long your
message is stored at the message centre.
Delivery report - Choose to receive confi rmation that your message was
delivered. Reply charging - Choose to be billed for your message recipient’s reply. Message centre number - Enter the details
for your message centre. Character encoding - Choose how your
characters are encoded. This impacts the size of your message and therefore data charges. Send long text as - Choose whether to
send your message as SMS or MMS when you enter a text longer than 2 pages in the message field.
Bearer setting - Choose whether to send your messages via GSM or GPRS. Changing your multimedia message
settings Your KC550 message settings are predefi
can do so using the Settings options. Press Menu, select Messaging, then choose Settings and Multimedia message.
You can make changes to:
Slide duration - Choose how long your
slides appear on screen. Priority - Choose the priority level of your
multimedia message. Validity period - Choose how long your
message is stored at the message centre. Delivery report - Choose to allow and/or request a delivery report.
FOR MORE SEE USER MANUAL
good luck
Mar 21, 2010 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
My son has had his lg gw520 for a fortnight and suddenly it won't send texts or save a message to draft. Fine in every other aspect. Is it broken or has he changed the settings without realising it and if...
i don't know if the network will have told you this, but i've just had the same problem, however i've discovered the source, which may apply to you too. if you go to menu, settings, phone settings, memory manager, handset reserved memory- here it'll show you that you have only the space for 500 messages, if it says 500/500 then you just need to delete some messages. hope this works for you, and saves you trouble of trawling through customer service at christmas
Dec 15, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Sony Ericsson S500i  Cellular Phone Logo
22 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
