Question about NorStar M7208 Corded Phone
How to program an internal extension number and then give it a name by using alphabet how to change a name tag on an existing internal extension number
    President:
  • NorStar Master
  • 860 Answers
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key. (or the clear key to erase)
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Posted on Feb 02, 2010
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
Panasonic kx-t7730
What are you using to program.
PT Programming or you are using a PC Tool?
Did you save after setting names?
Jan 02, 2014 | Panasonic BTS Panasonic KX-T7730 White...
How do i add a new phone to an existing system? I have connected the phone & just need to assign an extension number for it so that the other phones can see the system, thank you
If you have installed it on a new extension, it already has a number. By default, on a TA-series system, the jack and extension are the same, so Jack 12 is extension 112. Quickest way is to plug the phone in and dial 0. The main phone rings and the display will give you the extension number.
To program the buttons, press PROGRAM the button and dial 1 plus the extension number. The lines should already be programmed by default, but they are 0 plus 01, 02, 03 etc. Press STORE after each button you program.
If you want to program ringing and line access differently than it already is, you need to look in the Programming Manual for the specific phone system. The Panasonic cabinet is going to be white with a silver tag or a model number stenciled or embossed on the case. Something like TA-824 or TA-624 would probably be your system model.
Carl
Dec 15, 2009 | Panasonic KX-T7730 Corded Phone
How do I change a name on an internal extension?
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
Nov 09, 2009 | NorStar M7208 Corded Phone
How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Nov 09, 2009 | Panasonic KX-T7636W Corded Phone
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
Changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Apr 14, 2009 | Panasonic KX-T7633 Corded Phone
Changing the names for extensions
Name changes are done from the System Administrators phone. In the TA-series, it's system program 604. In a TAW it's 004. I can give you complete instructions, but you have to get to that screen first.
If you get there and want to play, the SP Phone FWD CONF MUTE and keypad press up to 7 times enter the Alphabet names (space is under 1). Nothing writes until you press STORE.
Carl
Oct 30, 2008 | Panasonic KX-T7730 Corded Phone
Revising extension directory on LCD
Correct. Changes are done in system programming. In a TDA it resides in system program 004. You get there by going to the main phone or phone used to program, dial PROG **1234 004 and enter the extension number of the name you want to change. It will display the present name and let you use the keypad to spell out new names. For example 2 gives you ABCabc2. The right arrow steps to the next character and ENTER saves it.
Carl
Sep 23, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic Adv Hybride System KX-T7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
NorStar M7208 Corded Phone Logo
399 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
