Question about Fisher and Paykel DEGX1 Electric Dryer
Hi My F&P dryer (model ED54) is making a continuous sound on plug it in....no lights etc turn on...just one long and continous BEEP!!....Help
  • Fisher and P... Master
  • 12,061 Answers
You dryers "Brain" the microprocessor, sounds like it has had a power spike, or spontaneous failure. You are going to need to get a "Quote" for a fix from a reputable repair centre/man
Posted on Feb 02, 2010
My whirlpool white magic 650 P produces contineous beep sound while connected to the electric plug. However the power switch and light indicators on the mechine is not working.
Sounds like you have a control logic issue. Either a button on the control panel is stuck, or the control board is defective. Find the model number on the unit and post it in the comments please.
Jan 11, 2015 | Whirlpool Washing Machines
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
What is the cause of continuous beep sound when a HP computer is powered-on
hi there! a continous beep comes about when memory cards are bad or not ment for the mother board .
Jun 03, 2013 | Computers & Internet
Instead of making a continuos beep its on and off
Your battery might be getting low on power or dying.
Jun 29, 2012 | Computers & Internet
5kg top washer not working, making a continuous beep sound
1) Test the voltage of machine vs the outlet wall from the house,
2) See if the frequency is 60hz or 50hz?
3) Tight the connectors very well inside, and tight any loose wires
4) Reset the machine. Turn off the c.breaker by 15 minutes, and tripped again, and Turn on again. If the problem persist you must call some service tech, the board can be faulty.
God bless you
Jun 21, 2012 | Fisher and Paykel Washing Machines
Dell PE 1800 showed one SCSI 73G non critical state on a RAID 5 array of 3 disks. Shutdown the server, removed the SCSI disk and booted, server booted but continous beep sound, trying to rebuild the array...
Hi, try to renew the drivers and firmware from here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PWE_1800&os=WNET&osl=en&catid=&impid=
Continuous beep related to ram ,try to remove ram and insert it, and if u still get beep change your ram.
Continious beeb sound is ram or cpu failure. Is the cpu fan spinning ??
If not the cpu is over heating.
Try to remove the ram modules and clean the contact points
with a piece of paper. Be very carefull when you do that !!!!!
And blow the dust out of your server, with a high pressure can.
Hope this was helpfull.
Mar 28, 2011 | Dell PowerEdge 1800 Server
In My APC UPS, continuous beep sound is coming with simultaneous Orange and Green lights are appearing
Unfortunately that signals an internal fault with the UPS and it requires immediate replacement / repair. Do not continue to use the UPS at all.
Mar 01, 2010 | APC (BE500U-WEB) (BE500UWEB) UPS System
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Beeping dryer
You should open the service panel and to find out where does the "beeping" unit located and to remove one of the wires connected to it (the unplugged wire should be insulated). Good luck!
Aug 20, 2007 | Miele Novotronic T230C Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
292 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
