Question about HP DeskJet 5150 InkJet Printer
My down arrow and power button are flashing - HP DeskJet 5150 InkJet Printer
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 73 Answers
The feeder of your printer is not function normally check the roller assembly
Posted on Feb 02, 2010
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Connecting direct tv todvr to a2005 20 inchrca sdtv channel code
1. Using Programming Codes
Find the TV code for your TV in the list from the Platinum Remote Control User's Guide (See References). For example, if you have a Kenwood TV, the three possible codes to try are 506, 573 and 712.
Press the "TV" button on the remote. Hold down the button until the "Sat," "VCR" and "Aux" buttons light up. Release the "TV" button and it will be flashing.
Enter the first code using the keypad. If you want the remote to control all functions on the TV, enter the code and press the # key. The "TV" button will flash three times.
Press the power button to turn off the TV and turn it back on again. If the code was correct, the TV will turn off and on. If the TV doesn't power down or back on, follow Step 6.
Try the next code from the list. Follow Steps 2 through 4 using each code until one turns off the TV.
2. Programming Without Codes
Press and release the "Power" button on the remote.
Press the arrow up key and stop. If the TV doesn't turn off, press the arrow up key again. Continue pressing the arrow up key until the TV turns off. Do not go fast when moving through the codes or you could miss the correct code. Press the arrow key and wait at least 20 seconds to see if the code works before pressing the arrow key again.
Press the # key on the remote when the TV turns off to lock in the code.
Jan 08, 2013 | RCA Televison & Video
I have an auto flash, but it's not flashing. Do I need to somehow turn this function on? If so, where is it?
Follow below mentioned steps to turn flash on:-
  • Rotate MODE DIAL to any one of them Auto, program, portrait, landscape, sport or night mode.
  • Press POWER button to turn power ON.
  • Press Navigation button (left arrow button), Flash mode change each time button is pressed. you can use UP and Down Arrow button to change settings. Set it to FLASH ON.
  • Press OK to confirm settings.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Feb 13, 2011 | Polaroid i936 Digital Camera
How do you turn off the little red filter llight above the low speed indicator?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 28, 2010 | Filter Queen Defender Air Purifier
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
Nov 19, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
I have a GoWalking by Sportline scale and right now it is set to kg but i need to set it to lbs how would i do that. i lost the manual pls help
Press I/O button to turn on.
While "1-10" is flashing, press "i" button once.
Use up/down arrows to choose a 'user number' from one to ten, then press "i" button.
Press up/down arrows to chose between male(bottom) and female(top) icons, then press "i" button.
Use up/down arrows to specify your height in cm. (inches x 2.54) Press "i" button.
Use up/down arrows to specify age, then press "i" button.
"1-10" will flash again. Using up/down arrows select the user number you've programmed and wait for your height and gender to display, followed by "0 lb." You can now use the "i" button to toggle lb/kg or step on the scale for your weight and body fat %.
Next time you turn the scale on, just use the up/down arrows to pick your user number then wait for the 0 display.
Jul 07, 2010 | Health & Beauty
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Won't power up
I had the same problem after I replaced my lamp. You need to hold down the:
On
Enter
Down Arrow
Right Arrow
simultaneously - this resets the lamp counter. After I did that my projector fired right back up.
Nov 22, 2007 | SharpVision XV-Z9000U Multimedia Projector
HP DeskJet 5150 InkJet Printer Logo
218 people viewed this question
Seeker5211
Seeker5211
