Question about Belkin (F5D7001) 802.11g/b Wireless Adapter
Can not change the wireless channel
I have a belkin f5d7001 that has been working to my router on channel 11 fine for 2 years but there are now 3 other near by routers on channel 11 so I decided to move to channel 6. The Belkin utility now does not see my router and insisits on connecting to 1 of the other routers on channel 11 dispite the "Connect to non-perferred" being un-checked. I have downloaded the lastest Belkin driver/utility software.
Running NetStumbler, with the same card/driver sees all the routers including mine on channel 6 and 2 laptops in the house also have no problems.
  • rob_latimer Feb 02, 2010
    Nice try but .....
    I have tried starting Wireless Zero Configuration service but the Belkin Utility stops me from using it (Belkin knows I want to use there great software) From the Belkin site there should be a check box on the utility to enable Wireless Zero Configuration but I can't find it (from elsewher it *may* only be available the 1st time you run the utility and removing and reinstalling it doesn't help as the settings are still in the registry) BTW I'm using WinXP Home and, as you know, not everything you can do in XP Pro is available in home.
    Novelist:
  • 108 Answers
A very good question!
I'd love to answer this. Belkin utility at times has some bugs. As you said you have downloaded the latest version of drivers and utility. Latest drivers are good but utility will not be of much use, I, as a technician would highly recommend that you use Wireless Zero Configuration in case of Win XP or WLAN Auto-config in case in case of Win Vista or Win 7. But if you have older versions of Windows, older than Win XP, only then utility has to be used. Enable WZC and WLAN A-C in Microsoft Services(Local) page.
Start > Run > services.msc > Ok > Services (Local) > Start the service.
At worst instances, if you are forced to use the utility, remove all SSID (wireless network names) from My Connections. Note: Remove all of them completely.
Also, i would recommend that you configure your wireless mode to be "802.11g only" on the router as F5D7001 is a 802.11g standard PCI card, and also turn ON the wireless PROTECTED MODE on the router. This will enhance the performance of your wireless devices in cases of heavy wireless traffic.
This is sure to work! Again, thanks for such a question.
Posted on Feb 02, 2010
Testimonial: "Everything you said was correct, but in the end I still can't get anything other than channel 11 to work. So is either driver (unlikely) or hardware."
  • Arvind Iyer
    Arvind Iyer Feb 02, 2010
    In the utility itself, under the tab OPTIONS, you have that option of "Use standard Win XP utility instead" under program choice. Try with that or the last option would be uncheck the Belkin name in msconfig > Start up. Note: Be careful with the System Configuration Utility.
    This will not boot the Belkin utility on the computer. But the drivers will remain. You can now use the WZC.
    Also, try the configuration on the router as i suggested, it ll also add on to the existing performance.
How do i secure my belkin router
BELKIN ::::
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 30, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ok..i used a different laptop yesterday here at my house and the computer asked for the router pin number....put that in and it worked fine...now my ipod touch will not connect tto the internet nor will...
BELKIN ::::
Regards
TOM
Jan 30, 2011 | Belkin Surf N300 Wireless N Router
I recently got an ipod touch, and i connected to the belkin wireless router with it and it was working fine. Then, all of a sudden, one day, it says there is no wireless network from it. How do i make...
WIRELESS ISSUES
Regard ,
Milan
Jan 08, 2011 | Belkin (F5D72304F5D7000) Router
When initially setup the router worked fine. However, after a computer crash and re-install, the desktop pc cannot find the router even though it is connected by Ethernet. Laptops will connect to the...
Dec 09, 2010 | Belkin Wireless Play Router (F7D4302)
New tv, when turned on, makes the Belkin Router ask for a new password on the Router management. If you turn the TV off the Router is fine.
Nov 28, 2010 | Belkin Wireless Share Router (F7D3302)
The router Belkin F5D7234 v4 has alredy included WPA2 sistem? Thanks
YES THE BELKIN F5D7234 HAS WPA2
Step 7 : Enable WPA/WPA2
Sep 13, 2010 | Belkin F5D7234-4 Router
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Aug 30, 2010 | Belkin Wireless Play Router (F7D4302)
Security light wont stay on belkin wireless router
Aug 29, 2010 | Belkin (F5D6230-3) Wireless Router
When I first connect the router on my pc using
You will need to change the channel first
Step 1 : Open RSP by typing 192.168.2.1 on the address bar of internet Explorer
Step 2 : On the Left Hand side under Wireless Click Channel and SSiD
Step 3 : Changed the Channel into 11 , or 9 And Apply Changes
Step 4 : Restart the router and test the connection
Step 5 : If it is still not working you may need to upgrade the Firmware from www.belkin.com/support
Let me know if it helped
At : warrierrakesh@ymail.com
Jan 03, 2010 | Belkin (F5D7230-4) Router (587009)
Router disconnection
1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
2. You will get a login page. Leave the password blank. Click Submit .
3. On the left side of the page, click Channel and SSID below Wireless .
4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel like 11. Click Apply Changes .
5. Click Logout in the top right hand corner.
6.Then reconnect to your wireless network.
May 17, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7001) 802.11g/b Wireless Adapter Logo
208 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
