Question about Sharper Image (SI714SL2) Compact Refrigerator
Sharper Image Compact Refrigerator (s1714sl2)
Sharper Image Compact Refrigerator s1714sl2
When turning the power does not go on when setting is on cold. If the setting is on hot, the power light is on, so I assume there is power. It also does not get cold.
  • 121 Answers
SOURCE: sharper image quadra professional series
I am a purifier dealer and this may be as simple as cleaning the unit. The ionzer plate should be soaked in a cleaning solution. Make sure all contact points are tight. The vpower boost it's self or a pc board maybe malfunctioning.
Posted on Sep 28, 2008
SOURCE: Sharper Image SA260
activate the reset button on the back of the unit (you'll need something like a toothpick or a needle to do this) this should do the trick (it did for me) hope this helps
Posted on Jan 14, 2009
  • 54 Answers
SOURCE: sharper image power tower 200
There is a small 1 1/2 inch O ring style belt that connects the motor to a set of gears. This belt is most likely broken and needs to be replaced.
Posted on Aug 05, 2009
Samspade30
  • 15 Answers
SOURCE: I need a 120v power supply circuit board
Ok here is the poop. I just tore mine apart the green light did not come on and the fan did not work. I looked at the circuit board I don’t know how many times before and missed a covered fuse. There is one (maybe it is a decoy) fuse that sits out in the open it was fine. But this fuse is next to the outlet wire on the circuit board was blown. It is small and covered with black shrink tape. This fuse is very easy to overlook. I unsoldered the ends and replaced the 12V 5 amp fuse. I used an inline fuse holder during replacement so if it goes out again I can just change the fuse. It is worth a look, good luck.
Posted on Aug 07, 2009
  • 50 Answers
SOURCE: Emerson Compact Refrigerator not cold.
Make sure the condenser fan is running, it is located near the compressor and blows across the condensing coils, and make sure the coils are clean. Compressors usually do get pretty hot though. And make sure all you fans are running in the inside
Posted on Aug 21, 2009
Testimonial: "I had to buy another one because the fan is not visible & I had no means of taking the back off. My dad will check the fan at home. Thank you!"
Smells of freon
Depending on whee the smell is originating from there is only a very small possibility that it would be refrigerant. More then likley burning plastic, melting ice, burning motor. Refrigerant doesn't actually have a smell. The only way you can get a wiff of something the leak would have to be substantial and then you would smell the oil vapor in the air and it would dissipate somewhat quickly. If you do not see oil anywhere you less than likely have a leak.
Sep 06, 2012 | Sharper Image (SI714SL2) Compact...
Model S1714SL2 - the fan is making more noise than normal
this could be one of two problems;
the fan is hitting a build up of ice. This could be the defrost timer or the defrost element
the fan's bearings have given out. a new fan motor will fix it
A technician can help you with that
Mar 24, 2011 | Sharper Image (SI714SL2) Compact...
Fridge is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgsjkysk
Sep 24, 2010 | Sharper Image (SI714SL2) Compact...
I need a power cord for Model S1714
You can use any 15 amp rating cable three core as the power cable of yourr fridge. Normally this is available in three colours, green for ground, brown for lead and blue for neutral.
If sealed plugs arre available it will be ideal or otherwise connect a plug seperately
Sep 16, 2010 | Sharper Image (SI714SL2) Compact...
purchase a AC to DC adaptor and use the 12volt power cord plugged into it.. these are commercially available, just make sure you purchase an adaptor that can handle the power used by the fridge which is on the back of the unit.
May 30, 2009 | Sharper Image (SI714SL2) Compact...
Sharper image power tower 200
May 17, 2009 | Sharper Image Power Tower Motorized DVD...
Fridge door handle is broken
door handle broken, wondering if i can get a replacement somewhere.thank you
Oct 15, 2008 | Sharper Image (SI714SL2) Compact...
Sharper Image Ionic Breeze Gp Silent Air Purifier
Ionic Breeze machines are no longer being supported. Sharper Image recalled the product several months ago after it was proven by Consumer Reports and the EPA that the product wasn't cleaning the air and can be harmful to use. Sharper Image took legal action and lost.
The Consumer Product Safety Comission is going to make a decision on all ionizers by the end of the year. It's looking like all ionizers will no longer be sold in the U.S. regardless of who makes them.
Aug 05, 2008 | Sharper Image Air Purifiers
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Sharper Image (SI714SL2) Compact Refrigerator Logo
305 people viewed this question
Top Sharper Image Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sharper Image Refrigerator Expert? Answer questions, earn points and help others
