No sound on GVG DV-995 DVD Player
I got this DVD player 4 years ago, i've never needed it until now. Just connected it up with the scart lead. Perfect picture, but no sound, i've checked the scart lead, even tried another one, but no success, even tried restore factory settings. Can anyone offer any helpful solutions, apart from get rid of it? Thanks.
4 Suggested Answers
rizla
  • 1463 Answers
SOURCE: NEW DVD PLAYER, PHILLIPS DVP3120 PICTURE SCROLLING RIGHT TO LEFT
have you tried the scarts they are fully inseted to dvd and also the tv , some times the cables become loose this can cuase this to happen .
riz.
Posted on Nov 20, 2007
SOURCE: I have connected my Bush DS-A332B dvd player to my
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Posted on Dec 28, 2009
SOURCE: Trying to connect a hitachi
how to set up
Posted on Feb 18, 2011
Philips DVD player no sound
Are you using a scart lead to connect to tv try changing lead as some times scart leads don't have all the pins I prefer to use scart leads that have all the pins in them and make sure they are firmly pushed home also check settings on tv as some tvs allow you to mute av plugs
Apr 10, 2014 | Philips Dvd Video Player
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
I have a pioneer dvd player dv-260 and on playback there is a picture but no sound .
this maybe due to the scart lead at back of dvd
try to make sure the scart lead is pushed in dvd and tv right
somtimes u have to **** them to make a proper conection
Sep 19, 2009 | Pioneer DV-260 DVD Player
I have a DV player, plugged into the AV2 scart socket but it will not start. The DV player works on another TV set. Do I need to programme it into my Bush TV no:WS6680SIL?
I tried the DVD payer and the scart lead on another TV and so discovered that it is the AV2 socket that is faulty. I am obtaining a quote for repair, in the meantime I can connect with the little cololoured leads instead of the scart.
Sep 17, 2009 | Bush Televison & Video
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
Help please......
Sep 14, 2009 | Televison & Video
Toshiba 3960 dvd player no sound
The most common causes,
1, bent or broken pins in scart lead.
2, faulty scart lead(internal wires broke)
3, mis-connected( audio out from dvd to audio out on tv.)
Just go through the list and if you have a known good scart lead, swap over to test.
Sep 04, 2009 | Toshiba HD-A20
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
Dvd video player model no DVP3120 unable to get player to play on tv setting AV1 at all but on tv setting AV2 player plays dvd`s but picture only no sound. it is connected using a Scart lead.
through a process of elimimation I identified the problem as a faulty scart lead
replaced lead and all was okey dokey
thanks for advice posted
colin the cat
Jan 22, 2008 | Televison & Video
Connecting tv to dvd player
It should be fairly straight forwards.. Simply get the SCART to SCART Cable.. Connect up the Two, DVD to Screen, turn them on, selecting any input/outputs Format etc, setups from any Menus...then start player select "Play" & ya should see the Picture & hear the sound...
Aug 31, 2007 | Philips 30PF9946 30 in. HD-Ready Plasma...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
