Question about Samsung SCX-4100 All-In-One Laser Printer
Thick black lines (of toner down each side of printed page
What causes thick black lines down either side of my printed page?
I have cleaned everything that I can, but the toner seems to be leaking out at either end of the roller. There seemed to be quite a lot of toner lying in the paper tray. Is this a job for a technician?
  • 115 Answers
There are problem in your toner, in toner there is a drum which are scratched, you have to replace this drum.
Problem will be resolve.
Regards
Ashly
Posted on Feb 02, 2010
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
CP2025N printing out with a thick yellow line down the left hand side of the page - any ideas why?
I had this problem, I believe from overuse/heat.
I removed the toner, gave the roll a clean, then set a clean through the printer and it should disappoint.
Feb 15, 2011 | HP Laserjet Cp2025n Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Prints thick black lines
Hello, Andrea.
Sounds like either your printer needs a new fuser assembly (If the teflon roller gets scratched or starts to disintegrate you will get lines or black marks on the page) or you need a replacement toner.
Hope this helps.
Sep 14, 2009 | Brother HL-5240 Laser Printer
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
I have a HP Colourjet 2600n which has worked well for 12 months plus. However it has just started printing with thick black smudges along the left of every page. It looks like there is yellow powder...
If you have BLACK Marks on the paper the YELLOW roller does not need to be cleaned usually.
To clean the yellow toner off the roller use a DRY lint free cloth. For this issue my suggestion for a resolution to the Yellow toner issue is replace the toner. They are not supposed to leak in the first place.
As for the BLACK tone on the left of the page you most likely have a Fuser issue causing that.
Jul 27, 2009 | HP Color LaserJet 2600n Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
759 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
