Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series top loader washing machine 110 volt was plugged bu mistake into 220 volt outlet. Machine will no longer fill water or agitate but when put into spinning it will spin
  • Kenmore Master
  • 3,740 Answers
First off I can tell you the water valve coils are probably cooked / burned out. With POWER OFF / unit unplugged you can remove one wire from each of the coils and check for resistance across the coils. No resistance = open coil = no fill. NO FILL = no agitate because the water level pressure switch is trying to sense the water level that never rises. If there is no water then there will be no agitation.
If you really want to see if it will agitate in it's current condition you can fill the unit with a garden hose on a low level water setting and fill it a little over half way to see if it will agitate. (You will have to remove the hose and close the lid)
If that works then the water vavle would be the culprit causing your condition. The wire wound in the coil windings of the water valve is smaller in thickness than a human hair and would easily fail if 220VAC was put across a 110V winding.
Posted on Feb 02, 2010
Washer wont spin or take out the water
Hi 1st remove cabinet by removing 2 screws securing the console to the cabinet top.pry clips at corners and remove .you should now be able to pull cabinet towards you and separate it from chasis .motor /pump at center front bottom.plastic plug on right, wiggle that plug with washer in spin probably bad connection in plug.red/black wire Hope this helps please rate my solution. :)
Jun 26, 2009 | Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
123 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
