Question about ASUS Computers & Internet
I have a M2N68-AM motherboard, and i want too uppgrade it whit a new cpu. like phenom 2 955 or 945. but what i can see on asus web site, my motherboard can only use C2, and moste shops only shows C3. so will it matter mutch?, and a nother thing, the update bios system allways ask after restart for flash disk, for some reson. dont know why, dont have flash driver. so: :P
  • johan kopperud Feb 02, 2010
    Sure it dose, but also its a AM2+, it fits a AM3 too. so not realy a anser to the question
    President:
  • 2,666 Answers
This motherboard supports Athlon 64 and Phenom processors that use the Socket AM2 interface
Posted on Feb 02, 2010
  • Alun Cox Feb 02, 2010
    If you think an AM3 socket CPU will work go ahead. The Mobo is AM2 rated only.
Can you tell me if AMD Phenom X4 9550 95W works with motherboard ASUS M2V-MX? Or if just that motherboard support quadcore CPU?
go to Asus web site and get the pecs for the board. it should tell you what processors will work with the board.
Feb 27, 2015 | AMD Phenom X4 9550, 2.2 GHz...
ASUS M2N68-AM SE2 sound driver free dounlod
You can download the audio and device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 03, 2012 | ASUS M2N68-AM SE2 Motherboard
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Hi. I get a blue screen with bad_pool_caller error, xp pro starts and stops and then blue screen and reboot forever. Is the motherboard (ASUS M2N68-AM SE2) in default. AMD PHENOM QUAD CORE CPU temperature...
Dear mariolama
It can be due to error in any newly installed hardware or software.
Most probably due to RAM. Check your RAM is perfect or not in other system. Or clean it and restart the system and check.
Reply me the status
Thank you for using FIXYA
Mar 14, 2011 | ASUS M2N68-AM SE2 Motherboard
M2N68-AM PLUS does not support cpu AMD Phenom 9750
No it does not. although it says it supports sockets AM2, AM2+, and AM3 and the Phenom 9750 is an AM2+, the Phenom 9750 has a wattage requirement of 125 watts. This motherboard ONLY supports CPU's up to 95watts! You would either need to get another motherboard or another CPU (or both and make a second computer).
Side note: also keep in mind that if using this motherboard with an AM2+ CPU, it will not be able to handle 1066MHZ memory (or higher) in dual channel mode, in order to get this speed you will either have to take out the second dimm or run both dimms at 800MHZ.
Hope this helps!! (and if it does, please rate or leave comment. It will be much appreciated!!)
Feb 12, 2011 | ASUS M2N68AM PLUS Motherboard AMD Athlon...
How i'm get free of cost asus m2n68-am se2 motherboard driver
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 21, 2010 | ASUS M2N68-AM SE2 Motherboard
It shows on startup ''a new cpu is inserted in your system'' with asus m2n68-am plus. its brand new.
You might have a combination of several small problems. I would like to know whick processor you have installed. But Here is how to get started:
1) Open the case (after unplugging the PSU, not just turning it off). Use a wrist grounding strap or touch the bare metal on the case frequently.
2) Pull the jumper off the 1st two pins of the RTC. Place them on the 2nd two pins for about 10 seconds. Pull them back off and place them back on the 1st two.
Plug the PSU back up and turn on the computer, pressing delete button when the fans come on.
3) This will enter the set up. Check to see if the correct CPU information is listed now. If not, the bios is not old enought to recognize the CPU.
4) activate Asus Update. Go to the site and update your bios from the site. You will have to clear the bios again after the new bios is updated.
5) at that time the motherboard's bios should recognize the CPU. This happens frequently with Asus boards particularly where you have an AM2 board or AM2+ and you are installing a Phenom AMD PCU.
Let me know how this works. There are other things we can do. This is the only thing about Asus boards I dislike.
Sirwriter
Nov 12, 2009 | ASUS M2N68-AM SE2 Motherboard
I just bought a asus M2N68-AM SE2 mob and a amd athlon 64x2 6000 processor and it comes up this model does not suport this cpu. others have same problem. I just want to no what cpu will work. what are...
Supports: AM2+ Quad-Core CPU/AM2 CPU and 45nm Phenom? II CPU Here is the complete list; your CPU is not listed. http://usa.asus.com/product.aspx?P_ID=2UWzsrOiRbMPGYpw
Oct 16, 2009 | ASUS M2N68-AM SE2 Motherboard
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
