Question about ZT Group Cisnet PC Desktop
Where can I find the specs so I can get a new RAM chip?
Its a CISNET CI-6001B. Its 240 pin, but what speed, etc. . Where do I look to find it?
  • ZT Group Master
  • 5,660 Answers
Working computer, and internet capable?
I would suggest using the free, tiny, little program, CPU-Z, (From CPUID.com), and you don't even have to open your computer case.
Information about CPU-Z on Wikipedia.org, and a view of the GUI used by CPU-Z.
(Graphical User Interface),
http://en.wikipedia.org/wiki/CPU-Z
(You can click on the screenshot at the upper right of this page, to enlarge it. This is what the GUI of CPU-Z actually looks like)
This is the CPU-Z homepage,
http://www.cpuid.com/cpuz.php
To download, go to the upper left of the page under the small purple heading - Download Latest version,
and left-click on - CPU-Z 1.53 setup (English)
A small window will come up. Left-click on Save File.
Where will this file go?
If you have your downloads set to save to your My Documents folder, (Start>My Documents), it will go there, or a sub-folder - Downloads, that is in My Documents.
If you do Not have your downloads set to save to your My Documents folder, this file will go to your desktop screen.
In either place, when you see the file name, cpuz_153_setup.exe,
Double-click right on it.
A Microsoft 'Squawk Box' will come up.
'Warning this software does not have a digital certificate, ....so on, and so on.
This is because the makers of CPU-Z, do not wish to pay big bucks to Microsoft, every time someone downloads their software for free!
The software is okay, I assure you.
Click on Run.
Follow the instructions. (It has been a while since I installed CPU-Z. I use it on all of my computers. You may have to click on - Accept, I do not remember at this time)
Why do I use CPU-Z, and recommend it?
1) It's free, truly works well, there is no malware attached, no junk mail comes with it, and it only works when I click on it.
(Isn't in your Start Menu to slow your computer down. You have to manually click on the CPU-Z icon on your desktop screen, in order for the program to run)
2) Not only will you get in-depth information about what ram memory you are currently using, and what ram memory slot/s it's located in, you will also get in-depth information about the rest of your hardware system resources.
A) Processor (CPU)
B) Mainboard (Motherboard)
C) Graphics
Plus what Operating System, build, and version.
My sources indicate, it uses an Intel Pentium 4 that has a Maximum frequency rate of 3.04GHz, 1MB of L2 cache, and is the Model 524.
Uses DDR Sdram, which has 184 gold plated contact pins, But, my sources could be wrong. (DDR2 Sdram has 240 contact pins)
If you need, or would like more information about CPU-Z after you have it downloaded, and running, please state so in a comment.
Posted on Feb 02, 2010
Testimonial: "Thank you. The description/explanation were thorough enough for a beginnner to follow. That CPU-ID program is gonna be on every computer I work with!"
  • joecoolvette
    joecoolvette Feb 03, 2010
    Thank you openers for your rating, and your testimonial.
    You are Most Kind!
Cant upgrade to 8gb
The spec for this model shows "4GB DDR3 memory" without mentioning the pin/speed specs. There are two types of ddr3 rams. one is 204 pin 1066 bus and others are 240 pin 1333 or more. By the config it has, i guess, it should be 1st kind of ram which is not what you would get if you ask for usual ddr3 ram. You can compare both ram side by side to see if the older one has less connectors. if so, you have to buy proper ram.
eg, here is an example link for that 204pin ddr3 i was talking about
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233080
Apr 02, 2013 | Acer Black AX3400G-U4802 Desktop PC with...
What ramm do i need and how much can i put in
You may use either DDR 400 or DDR2 533 RAM. These will be 184 or 240 pin chips, respectively. The maximum RAM for this motherboard is 2GB total, and you may only use one type of RAM; you are not able to combine different speeds of RAM.
May 07, 2011 | Foxconn P4M800P7MA-RS2 Motherboard
I need audio drivers for cisnet (ci-6001b)
you can download the driver from any of the link below
driver
-pro.com/hit/
forums.redflagdeals.com/cisnet-
www.fixya.com/...cisnet.../multimedia_audio_controller_driver_download
www.drivershq.com/drivers/cisnet/22800/Product
After downloading,install the driver on your device.remember to leave your comment about this post
Oct 25, 2010 | Computers & Internet
Memory
the max RAM speed, type, make etc for your machine will be normaly be specified in the motherboard specs....if ur MB supports only 333mhz but if u add 400mhz speed RAM it may not work properly, check the MB mfg for the correct specs of the compatibility.
Feb 18, 2010 | Matsonic MS9337c Motherboard
What bus speed memory do i need
I'm taking a guess that it's bus speed is 667 Mhz. This is based on the slowest RAM chips that will work on it, which are DDR2 RAM PC2-5300 240-Pin DIMM. You can however use, DDR2 PC2-8500,DDR2 PC2-6400, or DDR2 PC2-5300 speeds because the faster RAM is backwards compatible. It's best to install RAM chips in matching pairs for your machine.
Oct 15, 2009 | Acer Aspire™ T180 PC Desktop
RAM Memory Speed compatibility
all memory will operate at the slowest speed chip unfortunately. the only way to get the higher speed is to have all chips capeable of that particular speed.
Feb 14, 2009 | ASUS Computers & Internet
Hi i have a ram issue
specs for motherboard mach speed venom
Memory type ddr2 sdram
Memory slots 2 X 240 pin slots
Supported ram 800mhz 533mhz 400mhz 667mhz
I dont know if this will assist you in sorting problem out
Aug 02, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
Problem installing ram
You have the wrong memory chip. The beep code you hear indicates that there is no memory or incompatible memory. The memory you need is PC4200, Which is a 533mhz chip. Memory has a frequency rating that is matched to the processor and motherboard. Not just any DDR 200 pin memory that fits will work, the frequency has to match or it won't work. The new chip should be labeled, make sure it reads PC4200 or 533mhz, if it reads anything else it's the wrong chip. If it is the right frequency chip, then you may have a bad memory slot, the chip is bad, or mislabeled. Here's a link to a memory configurator that gives the memory specs for your machine.
http://patriotmem.com/configurator/modelp.jsp
Jul 31, 2008 | IBM ThinkPad R52 Notebook
Ram card
Hi giovanni2,
Sorry but you're board does not support DDR2 memory.
Only 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266). There are two PC Chips M871G.
One is M871G (V1.5) & the other is M871G (V3.1). Neither support DDR2 memory. DDR2 memory used DIMM slots with 240-pin. The memory slots on you're board uses 184-pin. The board will not function with 240-pin memory.
PC Chips M871G (V1.5) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=340&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
PC Chips M871G (V3.1) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=368&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | PC Chips M871G Motherboard
KINGSTON VALUE RAM 1GB PC3200 MEMORY
You have the answer in your question. I have checked the PC specification and you are right, it uses PC2700 memory. Therefore you need to install PC2700 memory. PC3200 memory will be the wrong speed and will not be supported.
Daryl
Apr 18, 2008 | Computers & Internet
ZT Group Cisnet  PC Desktop Logo
219 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
