Question about General M-D Building Products Purpose Box Beam Level, 24"
Repairing screw holes in corrugated iron
I am doubling the size of my shed (from 6 x 3 to 6 x 6) and wish to use the original corrugated iron as half of the 'new' roof. The iron is in excellent condition, however, the previous screw holes will not suit the new fixing locations. Is there some (easy) way to repair the old screw holes? e.g. a form of simple ''goof plug'', or am I destined to soldering or welding up the holes?
    Sniper:
  • 82 Answers
You dont mention how many holes there are to be sealed, I would assume less than 10? .. a couple of options spring to mind but there may be more!
1. Try using Eternibond sealing tape over the holes .. apparently good for 25-35 years! .. will need to clean the surrounding area carefully before application. Link to site http://www.eternabond.com/
2. You could always use the roofing screws and associated rubber grommets to ensure a watertight seal of the old holes. You may need to place some wood on the underside for the screws to bite into. This may be the cheapest option.
Hope this helps - if so, please leave feedback, if not let me know and I'll try and help some more!
Posted on Feb 02, 2010
Testimonial: "As usual from the professionals, two easy options that will be more than cost effective. Thanks for lending us your expertise!"
We have a bosch double oven. The screws that hold the heat shield to the oven ceiling have perished and am unable to get them out. I have new screws that I ordered on line. Is it possible to redrill new...
you will need some special tools if you want to use the proper replcement screws, you can try drilling out the existing screws with a drill bit one size smaller than the screws or you can purchase a kit called "AN EASY OUT" using this kit involves drilling a small pilot hole deep enogh to insert the proper size easy out and how it works is, it's designed to work like a left hand thread so you turn it and it grabs onto the screw material and allows you to turn out the scew, or just drill out the holes and replace with self tapping screws one size bigger than the original, hope this helps.
Sep 19, 2012 | Bosch HBL 455 Stainless Steel Electric...
I can find only one screw in the housing of the ep 8000 iron. What kind of screw driver does it take? Allen wrench doesn't engage.
Sounds like a 'TORX' head.
Does it look like a 'star' inside the screw head? A six-sided star? If so, then it is a TORX head.
Look carefully at it, and determine whether or not there is a small pin sticking out of the center.
The screw you are trying to remove is either a Flat-Head (-), a Philips (+) or a TORX (*).
You can get TORX bits almost anywhere, from the Hardware store, the Auto-parts store, to a Dollar store. You can get them with, or without, the little hole for the pin in the head.
You will probably want to buy a little 'set' that has multiple sizes of bits, and a driver, with an extension for reaching into those deep holes.
Jun 24, 2011 | Euro-Pro Steam Generator EP8001 Iron
I need a replacement screw that holds the soldering tip in place,I removed the screw,to take out the solder tip which I cleaned and on replacing screw and tightening it as tight as I can get it the tip is...
Chances are that the screw and maybe the hole in the iron barrel have been 'cross threaded'. Remove the screw and the tip, then examine the screw and hole threads for thread damage. If they are, the screw should be replaced, but the hole in the barrel will need to be cleaned with the proper size tap. You can find the tap and the screw at a home center, or hardware store , plus get some suggestions on how to fix your problem. Hope this helps!
Nov 10, 2010 | Weller SP80 Soldering Iron
Screws that hold bottom and top together have come out - appears that plastic that they screw into has melted
I repaired the broken "clamshell" of my Waring Pro WMK300 Professional Belgium Waffle Maker by replacing the original screws with a pair of (black metal) #8 x 1.125 inch flat-head machine screws and anti-vibration lock-nuts. These nuts have a nylon insert to prevent loosening. The assembly is now strong enough to pick up by the handle.
I drilled into the original plastic pits to create through-holes. I chose screws just long enough to fill the anti-vibration lock-nuts without protruding. You will need to hold each nut with a wrench or pliers while turning the screw into the nylon of the nut. Tighten just until the waffle iron assembly is snug, then another 1/8 turn. The torque should increase only during this last step.
The nuts are visible when I flip the iron, but I don't mind - they just remind me that the iron is now stronger than factory design.
Feb 23, 2010 | Waring WMK300 Professional Belgian Waffle...
Stirelia Steam Iron Repairing a faulty Valve as
my problem was with my Stirelia Steam Iron But do not wish to subsribe to your Repair plan Thankyou
Jan 02, 2010 | Simac Ice Cream Makers
Opened up a PS2 and square metal piece fell out
If you look on the left hand side of the top plastic bit you will see what looks like 3 holes. You have to place metal bit to match up with the central hole but in the other half. The smaller side fits in a perfectly sized hole.
Aug 27, 2009 | Sony PlayStation 2 (PS2) Console
Moved into house with damaged joint in external soil pipe from upstaira shower room
You didn't state the size of the pipe or if it is PVC(plastic) or Cast iron. Two rubber couplings can be used to repair the joint. A 12" section, 6" on either side of the joint needs to be cut out. Cut a piece of schedule 40 drain/waste pipe same diameter as existing pipe to size(just under 12"). Take two rubber couplings (sized for your pipe) and place on each end of pipe joint, and tighten clamps.
This fix will work on cast iron pipe, but there may be another means of repairing the joint, so get back to me with more info about the pipe and joint.
Aug 02, 2009 | Plumbing
Need screw size for Bose 901 Lifestyle speaker to mount to PS6's
Had the same question, e-mailed Bose support and they suggested "# 10 woodscrew, 4.5 mm diameter".
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
What size drill bit do I need to get a gas jet to a #63 size?
lp is a smaller hole so no drilling,you can get a convertion kit.
Nov 26, 2008 | Kitchen Appliances - Others
Rowenta DM 273 Iron
It is a Torx tamper proof screw-call 925-827-1011 and order a "Rowenta tool" $10.00 plus shipping this place allso sells Rowenta parts
Jun 13, 2008 | Rowenta Professional DX8800 Iron
General M-D Building Products  Purpose Box Beam Level, 24" Logo
414 people viewed this question
Top General Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a General Measuring Tool and Sensor Expert? Answer questions, earn points and help others
