Spin cycle not working,makes a loud rattling sound. could it be the cluch !!!
  • 5,911 Answers
More than likely (and more commonly) this is a broken motor coupling. This is a simple and inexpensive repair.
If the washer does not agitate or spin, but will STILL drain, the likely culprit is a broken motor coupling. You may also hear a loud rattling sound as the drive motor engages, but the tub no longer spins. Whirlpool uses a motor coupling in the place of a drive belt. It is located between the drive motor and and gearcase (transmission). This configuration is known as a "direct-drive" system. It is common for the coupler to wear out with age and break. Newer versions of this coupler are more resilient and resist breakage. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for the improved motor coupling is included in the link I provided. The average cost is about $10 - $15. You can purchase replacements at any of the following webistes:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. If you do not wish to order on line, take the part number provided and go to your nearest appliance parts retailer. This is a common part they should have in their in-store inventory.
If you have questions please post back with your model number (located on a nameplate along the wash tub rim under the lid). I hope this helps you.
Posted on Feb 02, 2010
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
Makes loud rattling sound in spin cycleloud and
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Motor makes loud rattling noise during rinse cycle
could be the coupler and the only way to truely check it is to take the pump, then the motor off. But it seems strange to me that you say it works fine. Is it spinning? usually when the coupler breaks it sounds horrible and usually will not spin but it will drain.I would check the coupler again.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine makes a loud rattling sound
Hi.k.
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
