Question about SanDisk 1GB microSD Memory Card
Sumsung microsd card - SanDisk 1GB microSD Memory Card
  • 239 Answers
Ya.. samsung microsd card..
whats the problem?
Posted on Feb 02, 2010
How do I change the SD card
Removing the microSD Card
To safely remove the microSD card from your device, you first need to unmount it.
WARNING: On the Android OS 2.3, you can download applications from Android Market and store them
on a microSD card as well as on the device. Due to this feature, skipping the unmount procedure can cause an error because information between the microSD card and the device is not accorded properly. In the worst case, the microSD card can be corrupted or damaged.
1. Press > > Settings>Storage>Unmount SD card.
Confirm your selection by tapping
OK.Now you can safely remove the microSD card.
2.Remove the back cover using the fingertip cutout at the bottom of the cover.
3. Gently press the microSD card in to release it and carefully pull it out of the slot.
Inserting the microSD Card
1. Remove the back cover using the fingertip cutout at the bottom of the cover.
2. Position the microSD card with the label side facing up and slide it into place until it is fully inserted
and locked in place.
Note
Be sure to
use only recommended microSD cards (up to 32GB). Using non-recommended microSD cards could cause data
loss and damage your device
Oct 19, 2014 | LG Optimus Slider
Microsd card won't read
You need to use a microSD card, not a microSDHC card. microSD cards max out at 2GB, anything larger is a microSDHC.
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
Feb 09, 2012 | Garmin nuvi 1390T Car GPS Receiver
Memory card unlocker
Micro SD (secure data) cards store information such as Word, image and video files.
Kingston microSD cards are used in many settings, such as schools, businesses and government offices, to protect data.
Some Kingston microSD cards are locked for added protection.
In the locked position, you cannot add or delete data from a microSD card.
You will need to unlock your Kingston microSD card in order to save data on it or delete data from it.
Remove the Kingston microSD card from whatever device it is kept in, whether it's a storage case, a digital camera or a GPS.
Find the small plastic switch on your Kingston microSD card.
If you are looking at the microSD card with the arrow pointing away from you, the switch will be on the right side of the card.
Flip the switch on the card to the unlocked position.
This will enable you to store and remove files on your Kingston microSD card.
http://www.kingston.com/flash/securedigital.asp
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
Add music directly from mac?
If your Mac system has a MicroSD reader, you can add music directly from MAC to the MicroSD Card. You can also insert the MicroSD card into USB compatible phone connect the phone to your MAC and Load your Music to your MicroSD card.
Jun 01, 2010 | PNY 2GB microSD Memory Card
Can I use a micro sd card from my nokia on my acer extensa 5235?
If your acer has an microSD card slot, you may use that provided that you have a microSD card adapter slot wherein you will insert the microSD card to the adapter. Then check if the adapter will fit the microSD card slot. IF it is not , then your acer has the SD card slot , not the microSD card...
May 16, 2010 | Computers & Internet
My LG Neon is not recognizing the microSD? card. it says "not supported". the memory card itself is microSD HC 8GB. it currently has music on it. not sure if that has anything to do with it.
Hi,the music on the memory card has nothing to do with it,the problem is that the memory card is not supported by the phone,the phone uses a microSD card quite alright but the maximum SD card it supports is 4gb microSD card that is why the 8gb microSD card is not supported by the phone.
so i'll suggest you get a 4gb microSD card.
Take care
Mar 10, 2010 | LG Neon GT365 Cell Phone
Where do i find the micro sd on the nokia 6300
Insert a microSD card
Use only compatible microSD cards approved by Nokia for use with this device. Nokia
uses approved industry standards for memory cards, but some brands may not be fully
compatible with this device. Incompatible cards may damage the card and the device
and corrupt data stored on the card.
1. Remove the back cover of the device.
2. Insert the card into the microSD card slot with the contact
surface facing down, and press it until it locks into place.
3. Close the back cover of the device.
Remove the microSD card
Important: Do not remove the memory card in the middle of an operation when
the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
You can remove or replace the microSD card during phone operation without switching
the device off.
1. Make sure that no application is currently accessing the microSD memory card.
2. Remove the back cover of the device.
3. Press the microSD card slightly in to release the lock.
4. Remove the microSD card from the slot.
Nov 28, 2009 | Samsung SGH-D900 Cellular Phone
I want sumsung sgh l700 driver
If your problem is transferring files between PC and SGH-L700, you have 3 options: USB cable (which you don't have), bluetooth connection and memory card.
If your PC has a bluetooth adapter, it's very easy: Just open both devices' bluetooth visibility, set a passkey for communication between them, then transfer the files in your phone using bluetooth.
The last option is, saving the data on your phone to the memory card (MicroSD) then inserting it to your PC using a simple (and very cheap) card reader. You can then transfer files between your two devices.
Feb 18, 2009 | Samsung SGH-L700 Cell Phone
1GB MicroSD card detecetd by computer as 0 memory device
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
SanDisk 1GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
