Question about Sewing Machines
My machine wont pick up the bobbin thread, and when it does, and I start sewing, it keeps jamming, and the thread locks around the bobbin spindle. It keeps sewing in one spot, which I have to cut the thread to get it loose. i have repeatedly taken out the bobbin and put it back in, but I keep having the same problem. Perhaps im not threading it right.
Check that the bobbin thread is pulled thru 'the tongue' of the bobbin case: that is what controls general tension of the lower thread. also make sure the upper thread is threaded thru the tension disk and the disk is 'grabbing it'.
Posted on Feb 02, 2010
How do I get machine case open to take care of thread jam around spindle
Um, you cannot fill a bobbin while it is loaded in the shuttle. To fill the bobbin, you have to remove it from the machine, go through other threading sequences and wind the bobbin on the outside of the machine. If you'd provide us with the make & model of your machine, we could probably help. With the information we've been provided, there's not much we can do.
Nov 03, 2016 | Sewing Machines
Why the bobbin wont wind correctly
My Brother has another spindle to wind the bobbin. Be sure to thread the thread through the two loops. I wind the thread around the bobbin a little and then start the machine. I find that using the cutter on the bobbin spindle helps to hold the thread on place.
Jul 06, 2014 | Baby Lock Ellure
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
Jul 18, 2012 | Singer 8280 Mechanical Sewing Machine
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
My sewing machine is like stuck or something the nob wont turn it wont sew it wont do any thing but make a noise
Is the thread jammed around the bobbin area? Open up the bobbin cover and check it all out, clean out any jammed or broken threads and rethread the machine.
The other thing to check is that the clucth in the side wheel is engaged. If you disengage the clutch to wind a bobbin, ensure that you engage it again to start sewing.
Hope this helps, otherwise it might be serviceman time.
Feb 27, 2011 | Brother XL-2600I
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
310 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
