Will not stay on startup keeps recycling - Televison & Video
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped you (or not), please rate, thank you!
Posted on Feb 02, 2010
STAYS ON RED AND KEEPS SAYING PLEASE WAIT AND REVERT BUT NOTHING HAPPENS
What kind of machine? This type of error would suggest that the machine is not able to complete the self test on startup.
Dec 07, 2014 | Office Equipment & Supplies
Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Dec 22, 2007 | Sony SLV-N55 VHS VCR
Sound but no video on startup
It seems that your OS has registry problem.
- Start PC in safe mode, normally Pressing F8 key when windows starts up.( Google it)
- In Safe Mode create a new user, with administrator privileges and protect it with password.
- Remove unwanted software's & programs.
- Empty the Recycle Bin.
- Download reliable program RegInOut to fix OS registry properly.
- Restart your PC normally and log on to the new account created.
Stay Happy :-)
Nov 18, 2013 | ASUS A7Sv-7S009C/Intel Core 2 Duo T7500,...
Pxe boot is it safe to remove from boot sequence
It goes to PXE, because it no longer sees the hard drive or OS. Boot into BIOS and verify hard drive exits. Go ahead and make it 1st boot.
If problems still exists, reseat or replace it.
Oct 12, 2012 | BenQ Computers & Internet
Recycles upon startup
Replace the bad capacitors in the power supply rate 2200 uf 10 vcd with a slightly higher voltage. That will fix the start up problem.
Jan 29, 2010 | Televison & Video
After the thermostat is switched on the furnace fires up but will not stay on and keeps recycling
take out the flame rod at the end of the burner assembly and gently wipe it down with a scotch brite pad and reinstall. This should tell the board that there is a flame established and it should stay on. If this doesnt work, the flame rod will need replaced
Jan 24, 2010 | Goodman GMS90703BXA Heater
Hi my philips monitor keeps flickering on and off. I hear a clicking sound but the monitor will not stay on.
You are hearing mini-sized lightning bolts.
Turn the monitor off, before it burns your house down.
Disconnect it.
Find a Recycling Station that will responsibly recycle your monitor.
Buy a new monitor.
Nov 01, 2009 | Philips Computers & Internet
My laptop (os windows xp) has been infected with iiiiii virus
iiiii is a virus program that transfers to the system through the USB devices. It keeps on hanging the OS at startup because it is pin at startup area of the OS.
Alternnatively, you can remove it by using a software that can bring out all the startup programs. The root of iiiiiiii.exe is in the C:\WINDOWS\SYSTEM32\XP6880 9. You can simply locate the root and get it deleted completely. Hold shift before deleting. Then empty the recycle bin and restart.
Good Luck
Feb 02, 2009 | HP Compaq Presario v3000z Notebook
Delete RECYCLER folder
Right click the recycle bin in 'my computer' or on the desktop and goto the properties. You may then configure the recycle bin for each drive or turn it off altogether. Once it is turned off for a particular drive you may remove the recycler folder (ignore the warning) it will not re-appear again when you delete files.
Oct 02, 2007 | Microsoft Windows XP Professional With...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
