Question about 2wire 2700HG-B Router (2700HGB)
ATT 2wire 2701 HG-DSL lite on, but bad connection
DSL, Power, internet, ethernet (flashing) lite on, has some internet, but msn keep logging out(on and off), web page stop loading halfway. sometimes refresh ok, sometimes no connection. tried my comp at my friends house, it was working, no problem. Called att, they said maybe power of the router, read some threads, i need filter, maybe the phone jack. Please help.
  • 1 more comment
  • psteve Jun 04, 2008
  • Anonymous Jun 28, 2008
    I've had ATT since last Nov and had simliar problems a couple of times. They replaced the modem once. The last time they sent a tech out and he put a splitter in the phone box outside to send a dedicated signal to the phone jack the dsl plugs into and it's been fine so far. He said I was 19,000 feet from their signal which is way to far so I was receiving a weak signal. Mike
  • Anonymous Mar 24, 2014
    interne goes out on router 2701 hg
I've had this problem several times. The last time they sent a tech out and he put a splitter in the box outside to send a dedicated signal to the jack the dsl is plugged into. No problems since. He said I was 19,000 from their signal and that was too farso I was receiving a weak signal. Mike
Posted on Jun 28, 2008
If you have a 2wire HG2701 it experiences problems. You will need a new modem or a new router. I have one but it has the same problems. I went to FRYS Electronics and bought an speedstream modem. WORKS PERFECTLY
Posted on Feb 20, 2008
Can the 2701 HG-B handle 6000-plus Kbps?
According to the setup screen, it can handle DSL link speeds up to 10692kbps (down) and 1036kbps (up)
I can't verify that it works, but... that's what it says
Jan 02, 2013 | 2wire 2700HG-B Router (2700HGB)
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
My 2wire has the power light red and the ethernet green and th wireless solid green and the dsl off and the internet off....what can i do
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at about 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
May 20, 2010 | 2wire (1000-000057-000) Modem
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
A friend gave me old 2Wire 1701HG wireless modem/router. It didn't come with power cord, cables etc. I found a 4.5V cord from old walkman that worked. Anyway, have ATT DSL service with speedstream 4100...
That would seem to be AT&T's favorite house brand...
Me thinks the SpeedStream was their SLOWEST
"DSL"
"2wire" was their next iteration of SLOW "DSL"
Yes... You will need to contact THEM ... or whom-so-ever is your INTERNET SERVICE PROVIDER (ISP)...
As I recall... the PRICE DIFFERENCE from one
service to the other was about $10 per month.
Give them your pirated modem number and they
will need to register it as a digital subscriber
in order for you to gain internet access.
Carnac the Magnificent
May 08, 2017 | 2wire Computers & Internet
Att 2701 hg-b modem
Hi , the 2701HG-B by default uses the last 3digits of the SN number as the SSID and the 10 digit number in brackets as the WEP key to access the user interface of the 2701 type in the address bar of your browser 192.168.1.254 and push enter, to access the interface program you will need to run the system set up and you must know the keycode from your service provider and the username and password
Jan 06, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Dsl
try opening a port your pc via the firewall on your router.
Jul 14, 2008 | 2wire HomePortal 1000HW DSL Modem and...
2wire 2700HG-B Router (2700HGB) Logo
1,369 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
