Question about Gaggia Paros Espresso Machine
I have not descaled my gaggia paros for a while now and surprise surprise it no longer works! I have tried descaling but no water is getting through. What should I do nex, does any one have a diagram of the boiler unit so that I can see where the problem may be? Thanks
  • winegoblet Feb 07, 2010
    Hi Adam
    Thanks for this, i have removed the brewhead and cleaned it but I can get the next piece off that has the copper pipe attached to it. Any tips?
    Thanks
  • 421 Answers
Have a look here:
http://www.partsguru.com/GaggiaTebeandParos.html
Your problem is almost deffinately the brew head. It will need to be removed, the backside of it cleaned and then reassembled.
Posted on Feb 02, 2010
Testimonial: "Thanks very much for schematic, v usefull. Any tips on how to get the brew head off. I have removed the screws that hold it but can't get it off "
  • Adam Peake Feb 08, 2010
    How badly scaled was the backsurface of the brewhead. If it was bad then i would now try the machine.
What does the red light descaling prompt light stay on? how can i know i have everything possible?
Fill it up the tank with descaler and start the machine on descaling. Leave it to trow all the liquid and must finish to the bottom,leave the machine to get AIR when descaler finished.Then the machine will stop and will tell you to put fresh water to clean . Fill the water tank to the MAX level and continue with the program. When the water is on minimum ,machine will stop,and the descaling process must be finished.
Good luck
Jan 11, 2018 | Gaggia Coffee Makers & Espresso Machines
I have a Gaggia Syncrony Compact machine which I am trying to descale. I have added the descaler to the water in the tank. when you hold down the button (26) more than 5 seconds nothing happens.What is the...
To descale the appliance proceed as follows:
• Mix the descaler with water as specified on
the package and fill the water tank.
• Switch ON the appliance with the ON/OFF
switch (7).
• Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
I noticed you did not mention the switch ON before you pushed button 26. Try that should work.
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Is vinegar ok to descale a gaggia classic?
1:2 solution vinegar to water should do the trick; rinse thoroughly!
May 12, 2010 | Gaggia Classic Espresso Machine
Gaggia Classic - water not flowing
Remove the screw and shower in the group, then press the brew button, if water flows then clean shower. I will send instructions for descale and backflush. Cut time for backflush by half.
Dec 09, 2008 | Gaggia Achille lever operated espresso...
Lack of water pressure
Try Descaling your machine with Descaling solution. Your group head may be clogged with calcium deposits which will cause a pressure loss.
If you need descaler you can purchase it at http://cerinicoffee.com/Dezcal_descaler_4pack.asp
Authorized Gaggia Service Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Aug 18, 2008 | Gaggia Baby Espresso Machine
Gaggia Paros Espresso Machine Logo
329 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
