Question about HP DeskJet 5652 InkJet Printer
5652 and Vista - duplex print not working
This printer not working on LPT cable, i connect it USB, duplex print on this driver not working.
  • 2 more comments
  • Anonymous Feb 28, 2008
    install printer as plug and play
    install plug and play printer
  • gear4all Dec 07, 2008
    Had the same problem, fix supplied by Bob Headrick solved the issue.
    After activating the duplex option duplex printing did not work correctly (rotated even pages).
    After the fix the rotation dissapeared and output is as expected.
    Good stuff!!!
  • siddharth kanojia
    siddharth kanojia Feb 23, 2009
    I had the same problem. Solution of Bob Headrick worked perfectly for my HP Deskjet 5652 duplex printer. Thanks for the help
    Scholar:
  • 137 Answers
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jun 21, 2008
    Sergeant:
  • HP Expert
  • 424 Answers
Posted on Feb 03, 2010
I installed in Vista the drivers for HP 990c. All my problems were solved, black printing, colored and duplex. Everything is working fine.
Posted on Dec 22, 2009
  • 3 Answers
I want driver DeskJet 5652
Posted on Jun 02, 2008
HP laserjet 1300n won't print duplex from vista
in the printer driver setting there is option to turn on manual duplex printing.
Go to printer driver properties go to printing default under printing default there is a option called finishing in finishing print on both sides is mentioned select that option and i m sure it should work
May 03, 2009 | HP LaserJet 1300n Printer
Note this casettee try not found fit to paper
U need to install the usb driver before proceeding to install printing driver for USB connection.
Apr 06, 2009 | Toshiba e-Studio163 Copier
Getting the Duplex Attachment to Work with Vista
what printer do you have?
brand and model?
do you has installed the newest driver and utility for vista operating system?
do you know that Vista and XP are incompatible in terms of drivers?
Vista has many drivers for a lots of printers, but these drivers are "generic driver". The generic driver is a small driver, an incomplete driver, and has a limited functions.
Sep 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
HP DeskJet 5652 InkJet Printer Logo
704 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
