Question about Kitchen Ranges
When the oven is off, a single 'beep' is heard, then the oven light comes on. The OVEN LIGHT button can be depressed & the light goes off. If left alone though, this cycle continues about every minute or so: BEEP, light comes on, then light goes off by itself; & continues. But, ALL the touch control panel buttons do not function, except for the START & CLEAR/OFF buttons only beep when depressed. The digital clock keeps time, but also cannot be adjusted. WHAT'S WRONG ? This unit has only been in home service for about 5 years since new, but was purchased earlier for our new home.
  • 2 more comments
  • Dave Kammerer Feb 04, 2010
    Obviously, some info was not included to you when I first sent this message to Fixya.
    It's a GE single convection oven model JT910, ser # HZ6 94401Q. (about a 1999 model)
    There was never any smell or error message displayed.
    During the malfunctioning, & in between, I was able to catch a couple times when it would accept touchpad controls. The first time I set it to bake, 200 degrees, & start. It went from 100 to 153, then shut off by itself & went blank. The START & CLEAR/OFF buttons were again the only two to beep when depressed. Then it continued to do it's cycle of oven light coming on & going off by itself, like before.
    5-10 minutes later I was able to 'gain control' of the touchpad again & it allowed me to hit BAKE, I entered 300 degrees & it got to 300 & worked normal. I left it there for about 5 minutes, then hit the OFF & it turned off.
    Since thay one day of malfunctioning, it's been working fine. What's going on ???
    Could something have been trigured by the oven heat to get it to work normal again?
    * * * And what would originally have caused the first problem of the oven light coming on by itself & doing it's cycling of coming on & going off by itself several times?
    I don't think so, but because the plastic control digital panel is right above the oven door opening; is there ever a problem with that panel getting too much oven heat? Because since we live in cold country, usually after using the oven in the past, we always prop the door open after the oven is turned off, to gain the residual oven heat into the kitchen. NO WARNING or guideline is printed in the owners manual, of NOT doing that.
    PLEASE ADVISE ,,,,,,,Thanks
    LOOK, I just spent 5 minutes retunrning (hit the SUBMIT below) a detailing comment to the person who replyed to me !!!
    Then my page comes back & says "Please reply an ACCEPT or REJECT notice" in red type.
    Before starting to type that message, I hit the "Return to (the same person)", & started my lengthy message.
    WHAT'S GOING ON !!!
    DO I HAVE TO RESEND MY ENTIRE REPLY I JUST "SUBMITTERD" !!!!
    The red type line appeared again......IT WAS TO "TARAN_2005" !!!
    IS HE/SHE GETTING MY MESSAGES !!!
    AND "NO", I'M NOT ACCEPTING HIS SOLUTION, as it first came !!!
    PLEASE ADVISE by tomorrow or I'm cancelling my subscription..................
  • 291 Answers
Sounds like a bad ERC (Electronic Range Control) or a bad touch pad assembly if you have an oven with a seperate touch pad. Fairly expensive to repair, and may be a result of a power surge in your area. Let me know the Make and Model of the oven and I can check for diagnostic codes on this, and whether you have a seperate touch panel. Thanks, Appliance Specialists
Posted on Feb 04, 2010
  • Norm Dickerson Feb 05, 2010
    Yes I see that you have already gone into some detail. We don't always see any other comment except for your first post. It sounds like your ERC had a computer glitch or your touch pad was sticking on one or more pads. Whenever we have wierd contol problems, we recommend that you first turn off the power to the unit, for about 30 minutes. This will reset the microcomputer/ERC board and can fix your problem quite a bit of the time. As to what I think your other comments were referring to, as we cannot see whatever the other technician was telling you. Heat from the oven, especially heat from the high temp self-cleaning cycle, does leak up into these controls and will damage them. Leaving the door open for the heating benefit is very bad for these microcomputer boards and touch pads. A good share of the oven conrol repairs that I do, are right after someone has just self-cleaned their oven. I recommend that you limit how often you self-clean to as little as possible, and that you reduce the oven cleaning time to 2 hours if it will allow you too. And you are right. The manufacturer should have a warning against leaving the door open to cool the oven down, or to use the residual heat for the house.
    One more thing, I looked up your model number, (you need to get the complete model off of the metal tag on the oven itself). It was missing 5 to 6 more numbers, but it did pull up about 10 models that were all very similar, single covection wall ovens. All of these had seperate ERC's and touch pad panels. If this fails again, reset the controls by powering off for 30 minutes, and if it still doesn't work, you may need to call a technician to determine whether it is the ERC, the touch panel, or both in some cases. Fairly expensive repairs. Good Luck again, Appliance Specialists
  • 10,515 Answers
Kindly Mention the Make and Model of the Oven?
Do you see any Error Message?
Any Smell, Any other Symptom?
Let me know, so that we could proceed further.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 02, 2010
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
GE profile convection double oven. Model#jkp56w0w1ww 1.The touch panel on the Oven is off and none of the button works. There is not light or code in the display area. 2. The light inside the oven...
Oh, you probably got this fixed already. If it happens again, it helps to take the control panel off, insert paper towel folded up neatly and slotted into the ribbon (it absorbs the moisture which causes the ribbon to short out). Sounds crazy but it's true! I saved our family hundreds of dollars with a piece of paper towel!
Aug 18, 2013 | GE Ovens
My oven light on my acubake whirlpool oven will not turn off it just beeps
Hello & Welcome to FixYa
The beep sound in oven is caused when either the door latch mechanism goes bad or the control board itself is bad. First check the door latch...if the problem is still there then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Whirlpool RBS275PD Electric Single Oven
When I turn my oven on to bake it goes on and starts to heat up during the preheat process. As soon as it's done with the preheat & goes to bake a #3 comes on my display and the button pas does not...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 23, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Gas ove will not stay lighting
Hi there you need to change the ffd on your oven FFd stands for flame faliure device. its like an temperature controlled switch. it is located in the oven and this device is what lets the gas go through once it has reached a certain temp. It must only be done by a corgi qualified engineer and to be honest your loooking at about 100 pounds.
Oct 08, 2006 | Baumatic B604SS Stainless Steel Gas Single...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
