Question about British Telecom Jabra BT500 Bluetooth Wireless Headset Headset
How to change the battery of jabra bluetooth bt500 . my bluetooth was not in use for more then 2years.. now im not able to switch on. i think battery is koncked off.. how to change this battery
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    How do i pair my jabra easygo to my phone
    Hold your blutooth switch on button at few second the light at bluetooth is starts to blink now open bluetooth menu in mobile select pared device and select search new device or go to blutooth menu and select search audio enhancement
    Apr 20, 2013 | Jabra EasyGo Bluetooth Headset
    Jabra BT2080 - been working well, charges and shows green charged light but bluetooth doesn't light up and unit shuts off.
    This problem is mostly associated with the battery of your device. In some cases, the battery is most likely to have expended it's lifespan.
    In this case, all you need to do is to change the battery. It is advised that you get a professional to change the battery for you as trying to do this yourself could lead to a damage in the device.
    Apr 23, 2011 | Jabra BT2080 Bluetooth Headset
    My headset will not turn on
    Hello
    Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
    Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
    Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
    If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
    Dec 30, 2010 | Jabra BT150 Wireless Headset
    Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
    The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
    Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
    Broken outer cover on Jabra Bluetooth headset with ear hook.
    no i don't think but go to the store wher u got it or call the counpney theat it is frfom and tell them the problem and they my get u a new 1
    Jun 07, 2009 | Jabra Bluetooth Headset with Adjustable...
    Vista cant install jabra bt8030
    I just got the same headset and they don't ship with a driver CD.
    Try using Bluesoleil for bluetooth connectivity on your laptop. You can get it from
    http://www.bluesoleil.com/
    Bluesoleil comes with its own drivers for a wide variety of bluetooth functions so you don't have to hunt for specific drivers.
    Please note that your bluetooth hardware has to be compatible with bluesoleil. There is is utility on their website that lets you test the same.
    Hope this helps.
    If this helps, can you have a look into my problem and see if you can help?
    http://www.fixya.com/ThreadView.aspx?prdid=919866&thid=2267585
    Thanks!
    Mar 11, 2009 | Jabra BT8030 Bluetooth Headset
    How to conf jabra bt150 bluetooth for nokia n73
    switch jabra off. switch cell on. turn bluetooth on. press "right hand" button next to middle button on cell to search for bluetooth devices. Hold down on switch and volume up switch TOGETHER on jabra. The cell then finds the jabra. I couldn't do this before I found Marie's problem below. Thanks for the info Marie!
    Nov 29, 2008 | Jabra BT150 Wireless Headset
    Jabra BT125 Bluetooth
    First u switch off the Jabra Headset..
    then switch ON the Bluetooth in ur Cell.
    then search for active devices in your cell..
    while searching switch ON the bluetooth Headset.press and hold it continuous until the light is on.
    you must hold it for approx 15 sec..
    then the jabra wil be displayed in your cellphone....
    tats it....add it....
    enjoy,,
    Nov 28, 2007 | Jabra BT125 Headset
    British Telecom Jabra BT500 Bluetooth Wireless Headset Headset Logo
    883 people viewed this question
    Top British Telecom Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a British Telecom Radio Communication Expert? Answer questions, earn points and help others
