I have purchased compex ADSL modem 16 months back and using regularly, For the last three months I disconnected the internet connection so the modem was not in use. Now I got internet connection but the modem is not working. Servicemen from broadband service checked and found that the model is under repair and also suggested to buy a new modem. My question is. Shall I go for a new one or repair the existing.. Please resolve Thanks Thiyagarajan
    Guru:
  • 480 Answers
One thing you can do.
Try to download an updated firmware for from the manufacturer of the DSL modem.
In most of the cases this will resolve the issue that you are describing.
Lastly I would suggest to buy new one if it stills does not work
Thks
Uttam
Posted on Feb 02, 2010
I have resetted COMPEX WRL254G Wireless all in one ADSL MODEM/ROUTER..but when connecting the LED for the INTERNET option is not glowing and hence not able to connect to internet..kindly give me...
Call your internet provider, and ask for your User Id and password. Probably you will need extra help to setup your router, but Im confident your internet provider will help you.
Sep 20, 2012 | Computers & Internet
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
My M1255nf works fine except that since we moved last month, when I get ready to send a fax the line is very noisey even with the phone line removed. I tried replacing the fax card but still same noise. I...
Do you have ADSL internet in your new place? If so you will need an ADSL filter plugged into the phone outlet and plugged into your fax machine. so it would look like phone wall jack--->filter-->fax machine.
ADSL internet creates it own jabber or digital noise in the line and the filter will stop your a analog device from hearing the noise. If you don't have a filter for your phone as well, you should get one. Without filters your ADSL internet will be slower as well. Your ADSL modem should have came with at least 4 filters, if not they can be purchased at your local Bestbuy, staples or computer place. NOTE: Filters only work if you have ADSL or DSL internet.
If you do not have ADSL or DSL internet and still have noise you may have to call your phone service provider to get them to diagnose your line issues. They can fix some noise issues from their end.
Chris
Sep 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
Have ADSL Modem and Wireless Router, i connect with UTP cable so dont have internet in my wireless router... I connect my laptop to modem directly and have internet... Whats wrong...??
the wireless router is not properly configured... configure ur adsl and disable dhcp server in the same. and then disconnect it ... then configure ur wifi router with a static internet address that is from the adsl range . put the default gateway as the adsl and save it, connect the adsl to wifi and switch both of them on... ur done... but make sure if ur adsl address is 192.168.1.1 the ur wifi address is 192.168.10.1
Jan 10, 2010 | Cnet CWR-854 Router
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Last light on modem not working
reset the modem by removing power for a coulpe of minutes and then power it up wait a minute for the modem to reset and then try to connect to the internet
kind regards and please don't forget to rate us
Dec 11, 2008 | NetGear DM602 ADSL-Modem
ADSL Router wont get ip address from operator
sir if your ISP account is PPPoE or using username and password to connect, try to open your router using web interface configuration, locate your account and try to disconnect then connect.  hard reset afterwards(on/off the device)
if your using a dynamic account, try to RESET your modem and do the hard reset.  check your IP using command prompt, to do this type ipconfig /release, when it releases to zeros, type ipconfig /renew to have your IP's back...check internet connection then
Winsor
Sep 02, 2008 | Zyxel P660HW-D1 Router
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
