Question about Roper REX5635E Dryer
I'm trying to figure out where part #3346 goes on a roper REX5634. Pretty simple right? But I can't find it anywhere and no where looks obvious. help! Pleeez
    President:
  • 2,468 Answers
If your part number is correct it would be the idler pulley tensioner for the drum belt and installs right next to the dryer motor inside the units lower area to keep belt tension on the drum belt
Posted on Feb 03, 2010
Subaru2.0GX master cylinder
http://download.howtosimplified.com/index.jhtml?partner=^AW6^xdm003&gclid=CMbvus_j77sCFatxQgod9TEA1g
Just found this from a quick search. See if it helps.
Jan 08, 2014 | Subaru Impreza Cars & Trucks
Fuse blows every time on power supply board
One of two general things is wrong here : either you have a short at the input section of the power supply--bridge should block it from getting to main input filters==== or if fuse was replaced it is wrong=explanation?
Most of these sets use a special fuse--if a surge or even a problem takes it out the fuse must be replaced with the CORRECT one, amperage and voltage rating aside many of the fuses are thermal or special slow blow types---put a generic fuse of proper rating in and it can pop instantly for no reason.
Other than that it has to be between the input for the power cord and the output of the bridge or even further down on primary side of actual power supply===usually another diode is in line after the bridge will prevent it getting to the main input filters.
If reference to Steve is directed at me that is my name---pretty simple repair and as far as that bridge goes if it is attached to a a heat sink you better remove the sink and look at the bridge with your eyes---seen more than a few where it tested good but was fractured at heat sink--when power hits it can arc right to the metal and fuse goes instantly.
You have a very limited number of possible parts (other than wrong fuse) that can cause this====try to isolate issue with simple tests.............
May 20, 2012 | Olevia LT42HVi 42 in. LCD Television
How do I take apart the strainer section?
Everything should just lift up and off. May be
juice stuck together. Try a little tap to the whole
assembly.
Mar 04, 2010 | Acme 6001 Juice Extractor
Can't figure out how to load new cartridge
Just pull the old one out and push the new one in until it clicks. It is hard to express in writing but it is easy to do. Just realize that there is no magic involved. Pay attention to what you are doing, be gentle, but firm and do it.
It comes out the front and goes back in the same way it came out.
Oct 06, 2009 | Brother HL-2040 Laser Printer
I have a roper washing machine Model# RAX 4232RQ4 that leaks water near the front, checked hoses and drain all seemed fine, how do I disassemble cabinet to look at?
it may be a bad pump they are usually toward the fron of the washer. Just tip it back far enough so you can look under it while laying on your back make sure it doesn't come back down on you. When a pump goes bad it will leak where it connects to the motor shat. simple and easy to change Good Luck.
Mar 23, 2009 | Roper RAS8445KQ Top Load Washer
I cannot locate vacuum bags for my Euro Pro 790 Shark Canister!
http://www.sharkvac.com/
You have to put it in like this: EP709 to get results. If you use lowercase or put a space, nothing comes up. (It took me about 5 minutes to figure this out....)
This is the direct link to the bags:
http://www.sharkvac.com/productDetails.aspx?ProdID=LJK8vNj9Ulo%3d
hopefully it will get you there.
I ordered three packs of bags because this process is such a nightmare.
I'm really hoping I ordered what I think I ordered. It's not very easy to tell....
Feb 11, 2009 | Roper RGS7646KQ Gas Dryer
No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Nov 21, 2007 | Technics RP-HP1200 Headphones
Dryers Logo
49 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
