Question about Ryobi Garden
How do I replace the recoil spring for a Ryobi 990R trimmer
panilling9
  • 284 Answers
SOURCE: ryobi 990r trimmer
alot of trimmers now have limiter caps on the carbruetors to keep the homeowner from making adjustments due to epa regulations and the ethanol fuel is 10% is not good either
So unless you have access to or a way to remove the caps for adjustments its a hard fix
you could remove the carb. and take apart to make sure the rubber pieces are still pliable.
the fuel will harden them over time and the carb will not deliver fuel to engine properly.
check you fuel lines to make sure they are not cracked or broken
Posted on May 26, 2009
  • 120 Answers
SOURCE: Pull cord on TB25CS trimmer came out all the way, won't recoil
http://www.m-and-d.com/pdfs/MTD/TB25CS-41BDT25C063PL.pdf
Probably the recoil spring is broken.
Posted on Aug 24, 2009
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
SOURCE: trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
Posted on Jul 04, 2010
SOURCE: Gentlemen, I have a Mighty lite Trimmer of which
I have the same problem....the cord remains out...so I pulled it apart and discovered that the recoil wheel that the cord rewinds onto does not stay where it is supposed to and rides upward catching on the fixings that hold it in place. When i pressed it down the cord retratcts immediatley. Only problem is it does not stay there. It was only used three times.
It has everything to do with being a cheap product. I should have paid a little more and bought a better product. Will not buy homelite again.
Posted on Aug 24, 2010
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Ryobi line trimmer cord won't retract. We have been told needs new spring, no parts? what can we do
They sell starter springs for Ryobi recoil units right here on the internet. Why do you say...no parts? Are you in Austrailia? Go on this site and enter the model of the trimmer to observe the parts available for it. If you don't like the price, at least you'll have an idea of the part number and pricing too.
Feb 02, 2011 | Garden
I have a Ryobi 700R trimmer - I need to know how to replace the pull cord - Tom
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case:
1. Disconnect the shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts).
3. Pull the cord until the stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
Use proper line and reverse for new line. Good luck!
Aug 31, 2010 | Ryobi Garden
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trying to replace pull cord on ryobi cs30. How do
May 22, 2010 | Ryobi Garden
I have no spark on my ryobi 990r. i have replaced sparkplug. i have checked and have plenty of fuel
make sure the gap on the plug isnot to wide other wise u will not get any spark or just a weak spark
May 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Howdo I fit a new pull start cord on a ryobi 25cc
remove the plastic housing to gain access to the recoil. Pull the cord slowly all the way out,this will cause the spring to wind up.Clamp the recoil wheel so it will not return to its original position,be carefull the recoil has tension on it not remove the old pull rope and thread the new one in and thru the hole of the recoil tie knot.pull on the cord to take tension off and at the same time remove clamp. Slowly allow the recoil to wind the rope in and reinstall on unit.
Dec 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Just tried starting my ryobi trimmer and the recoil spring on the starter rope will not rewind is their and easy fix?
if ti didnt retract chances are the spring is broken and will need to be replaced
Aug 23, 2009 | Garden
How to replace recoil assembly on roybi 780r
have ryobi 780r and primer bulb won't show fuel pressed and fuel comes out of fuel cap,i have pressure in fuel tank. it ran 2 weeks ago great?
Jul 01, 2009 | Ryobi Garden
Garden Logo
418 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
