Question about Tascam FW-1884 Firewire Audio / Midi Interface Sound Card
#1 the controller is not listd naymore under where the Midi conrolleesare, #2 Whe I open the "Volume Control" icon on my desktop, instead of showing the device it deisplai an error "There are no active mixers avalalable", I'm sure the 2 issues are related
  • 4,924 Answers
Reinstall the sound driver ...this should get it to the default ..after that be sure you have the midi connection ok ..and all drivers installed....to get to see the firewire connection go to the device manager by right click on my computer and properties /hardware and device manager
here if it is not visible ..just click righ on the computer and than scan for hardware changes ...if it is a connection made..it will appear ..probably called IEEE or so ...and ..if it will appear in yellow with a ask sign it means that you still needa driver for it..
In regards of the volume controls ...double click on the tray icon ..and than click on options ..and locate and add the midi volume from the list ...
Posted on Feb 02, 2010
The icon for my volume control is no longer on the taskbar. I went to my control panel and then to Taskbar and Startup Menu. I clicked on the Notification tab that asks which icons to always show The...
I had the same problem with my VAIO. You may want to try the MS Tech Support article to troubleshoot. It's helped some people get the volume control in the sys tray again: http://support.microsoft.com/kb/319095/en-us
I had to do a workaround and put a link to the volume control setting on my desktop:
1. Right click on the desktop. A menu will pop up.
2. Scroll down to New.
3. Choose Shortcut.
2. For Location of the Item, type the following: c:\windows\system32\sndvol32.exe
3. Click next
4. Call the shorcut whatever you wish. For example, Volume Control.
5. Click Finish
You now should have a functioning shortcut on the desktop provided the sndvol32.exe file is not corrupt (see Microsoft article).
Steve G.
Jan 20, 2011 | Sony VAIO PCG-K35 Notebook
Yes sound problem pls helo me now
From the Taskbar located at the bottom of your computer click once on the "Volume" icon.
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Right click on the "Volume" icon.
Select "Open Volume Control."
Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW Synth (short for synthesizer), CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
Right click on the "Volume Control" icon.
5
Select "Sounds and Audio Devices Properties."
Under the "Volume" tab, slide the "Device Volume" indicator to High.
6
Under the "Speaker Settings," click on "Speaker Volume."
Slide the "Left" and "Right" volume indicators to "High."
7
Click "OK." If this does not fix your sound issue, proceed to step 8.
8
Go to the "Hardware" tab and select the "Driver" tab.
9
Make sure you are connected to the Internet and then, Click on "Update Driver."
10
After the driver has been updated, Click "OK."
11
Exit.
Thanks.
Oct 10, 2010 | Computers & Internet
I cant get any sound on my computer. it is telling meno audio output device installed. and is pluged in
Please just follow the steps to fix the problem
  1. Step 1 From the Task bar located at the bottom of your computer click once on the "Volume" icon.
  2. Step 2 Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
  3. Step 3 Right click on the "Volume" icon.
  4. Step 4 Select "Open Volume Control."
  5. Step 5 Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW synthesizer, CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
  6. Step 6 Right click on the "Volume Control" icon.
  7. Step 7 Select "Sounds and Audio Devices Properties."
  8. Step 8 Under the "Volume" tab, slide the "Device Volume" indicator to High.
  9. Step 9 Under the "Speaker Settings," click on "Speaker Volume."
  10. Step 10 Slide the "Left" and "Right" volume indicators to "High."
  11. Step 11 Click "OK." If this does not fix your sound issue, proceed to step 12.
  12. Step 12 Right click on the "Volume Control" icon.
  13. Step 13 Select "Sounds and Audio Devices Properties."
  14. Step 14 Go to the "Hardware" tab and select the "Driver" tab.
  15. Step 15 Make sure you are connected to the Internet and then, Click on "Update Driver."
  16. Step 16 After the driver has been updated, Click "OK."
  17. Step 17 Exit.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 31, 2010 | E-Machines eMachines Desktop PC
Volume icon
Hi, pullmyfin597. check your computer in the device manager if you have audio drivers. Or Try to check the control panel:
Click start > control panel > sound then under playback tab, tick
the box show icon on desktop. Then the volume control will show up on your desktop screen.
May 05, 2010 | Microsoft Windows Vista Home Premium...
I dont have volume icon in my task bar. sound r working. just icon iz not there when i ''select show icon in task bar it says that '' volume control programe not installed
Are you using WinXP?
Is so open
SETTINGS
CONTROL PANEL
SOUND AND AUDIO DEVICE
First window opens make sure the checkbox is checked that says
"Place Volumn Icon in Taskbar"
Jul 18, 2009 | Computers & Internet
I have lost the volume control icon from the desktop toolbar and want to restore it
To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet.
May 21, 2009 | Dell Inspiron 1501 Notebook
Missing icon
click 'control panel'
click 'Sounds and Audio Devices'
Check the box that says 'Place volume icon in the task bar'
Dec 11, 2008 | Gateway GT5404 PC Desktop
Onscreen volume display not showing up naymore
Try this out:
Click the Start button on Windows Taskbar located at the bottom
side of the screen and then select Programs, Hot Key Manager,
Configuration from the menus that appear.
To enable onscreen volume control message,
check the Show volume controls onscreen checkbox.
This is the recipe for the 2000-model, but I believe it should be the same for the 5000.
The manual for the 5000 can be found here: http://support.benq.com/files/Joybook/Manual/5000_English.pdf
Dec 03, 2008 | BenQ Joybook 5000U Notebook
My computer
If your using any ver.of XP. Click the start button slide up to & open control panel. Double left click Sound and Audio devices icon.
Sound an Audio Device Properties window will open. Click the Audio tab. Under Default device: is the sound cards name. Click the Voice tab. The same device name should be listed under Default device. Lastly click the Volume tab. Put a check in the box (by clicking one on the emty box), next to, Place volume icon in the taskbar. Within seconds your volume controll will show up down by the clock.
Have more questions, feel free to ask.
Good Luck!
Mike
Mar 26, 2008 | Computers & Internet
Tascam FW-1884 Firewire Audio / Midi Interface Sound Card Logo
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
