Question about Vacuums
How to take apart Nilfisk Action Plus to replace spring loaded cord retriever
2 Suggested Answers
SOURCE: Nilfisk GSD
are you talking abour exterior spring clips?
Posted on Jul 26, 2008
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
How do I open a Nilfisk Action Plus vacuum cleaner?
l have a question but no answer for your question--is switch actually broken or unit will not power on?
Dec 17, 2012 | Vacuums
How to open
If you are having trouble with your Nilfisk vacuum and you are in teh Melbourne area we can help you directly. If you are somewhere else you can use the contact us form and request a parts diagram which will help you if you want to pull it apart. Please be sure to include the model number.
Jul 14, 2012 | Nilfisk Vacuums
Cable will not retract
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
Feb 18, 2012 | Nilfisk Vacuums
Looking for repair manual on the Nilfisk Kink Type Great Dane
I would be happy to send you a parts diagram for your machine if you want to request a diagram through he contact us form on our website. I have also made a video pulling one of these machines apart which may be helpful.
Jan 20, 2012 | Nilfisk Vacuums
My kenmore progressive caniser needs a new power cord. the plug had one of the metal prongs break on the plug. how can I replace the cord? model 22812201
I do not know if you want to replace the replace the power cord or the receptacle for the power wand?
If you need the prong for the power cord you can purchase a replacement power plug from a local hardware store and it will function and look reasonable. If you want it to look like the original factory plug you can purchase the plug from the following link for $29.56 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=4370695&productGroupId=0020&supplierId=116&mv=rr
You could also purchase the cord and retractable reel if you want to make it easier for $53.38 plus shipping by clicking on the following link.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8192087&productGroupId=0020&supplierId=116&mv=rr
Clicking on the links below will show the exploded parts view so you can see how to disassemble the unit to replace the cord.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00003.png
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00001.png
If you need the power wand plug click on the bellow link for $21.99 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8175251&productGroupId=0020&supplierId=116&mv=rr
I hope this helps and is the information you needed.
Jun 22, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Nilfisk king 540: The cable is stuck. I can´t take it out
Tools required: Haxalobular screwdriver (Torx or 'Star'), Strong hands/fingers, flathead screwdriver.
Possible hazards: sharp edges (metal plastic), bacteria enriched dust/dirt.
Notice the black ring/skirt near the bottom of the unit...sit on the vacuum cleaner, and pull very firmly at the ring, which will begin to click and pull upwards, rotate around the unit pulling the ring up until the whole ring comes off and you can pull it off over the top of the unit.
Now, there will be a white plastic ring revealed around the unit, using a Flat Head screwdriver to pry the ring out of the grooves it sits in (pull it off towards the bottom of the unit as opposed to the intial black ring coming off upwards).
Now take the handle of the unit and give a firm **** upwards, the whole encasement will slide off in your hand.
You will now see the spring loaded cord retracter. The problem here is that the spring has become too losely wound back onto the larger spindle, or it is dirty.
Firstly pull the entire power cord through the outer shell that you removed (you will need to unscrew and remove the black facade that the cord goes through otherwise the head of the cord wont go through).
Then take the plastic cirlce cover off the smaller spindle (carefully as the wound tin spring could pounce).
Now you need to manually turn the larger wheel clockwise until it has no coil left on it, and the smaller coil now is full.
While winding, dont let the powercord wind back onto the wheel, let it sit to the side (there will be a bit of tangle which will go back to normal when we finish winding back the other way).
Once it is fully loaded onto the smaller coil, wind it back on to the larger coil again, but make sure it's loading on 'tight'. You can ensure this by keeping some pressure on the smaller spindle while winding (be carefull because the coil edge is sharp). Once the smaller coil is basically gone and there is just a small curved end of the coil, put the small spindle back on making the curved coil wrap around it.
Wind some coil back onto the smaller spindle so there is atleast one full ring plus a small overlap, around the spindle, or it may come off. Also, make sure that where the cord is coming out of the larger spindle, is pointing towards where it goes out the back of the vacuum cleaner, so that when you pull the cable it wont wind the wheel at all, otherwise it may wind some coil off the smaller spindle.
Proceed to put the unit back together, but before putting the white and black rings back on, test the retract button. I noticed the first attempt to put it back together that the external button had not lined up with the internal mechanism and it wouldnt retract, i had to open it again.
All done, it should now retract, but it will never be as strong as the day you bought it, but atleast you dont have to have the cord hanging round. Hope this helps.
May 18, 2009 | Vacuums
Nilfisk GSD
Jul 06, 2008 | Nilfisk GM 80 Bagged Canister Vacuum
Vacuums Logo
666 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
