Question about Lexmark F4270 Plain Paper Inkjet Fax
Won't send faxes
I am trying to send a fax with my lexmark all in one fax printer. the button is in fax mode but I keep dialing the number to send the fax and the lcd stays on the copy screen. I am very frustrated. all the cables are properly connected and properly plugged in phone line.
  • bellaartista Mar 21, 2008
    won't recieve faxes
Hola. yo quiero saber como programar mi fax.
Posted on Mar 25, 2008
  • 168 Answers
Did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Posted on Feb 19, 2008
Lexmark X4270 won't send out a fax
If you have DSL. you need a filter on the line you are trying to fax through.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2012 | Lexmark X4270 All-In-One InkJet Printer
Iam getting remote fax error
Please try this approach:
1. Try to resend the fax. There may have been a problem with the quality of the connection.
2. Decrease the transmission speed of your fax modem. Press Setup button > Fax Setup > Dialing and Sending > Max Send Speed > 9600. Resend the fax.
3. Re-register your user information - fax name and fax number. Some fax machines block faxes without sender information. Press Setup button > Fax Setup > Dialing and Sending > Your Fax Name (re-enter your fax name). Follow the same steps and go to Your Fax Number - re-enter your fax number. Resend the fax.
I hope this helps.
Feb 20, 2012 | Lexmark Platinum Pro905 multifunction...
I can't get the fax to work on S405 all in one - did work but now has decided not to but I haven't changed anything!!
I hope this helps.
Jan 19, 2012 | Lexmark Interpret S405 Wireless All-in-One...
I get a remote fax error when trying to send a fax...i have a Lexmark X5070 all in one printer/fax
The problem could be due to the quality of the telephone line connection. Try to resend the fax.
Lower the transmission speed. Follow the steps below:
  1. From the printer operator panel, press Fax mode.
  2. Press the menu button.
  3. Select Fax Setup.
  4. Select Dialing and Sending.
  5. Select Max Send Speed.
  6. Lower the speed to 9600 bps.
  7. Press check button.
Try to send a fax to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
How do you load a lexmark X5650 all in one printer, copy, photo, scan, and fax? I am trying to figure out how to load the fax to send the fax to someone.
Sending a fax using the printer control panel:
  1. Make sure the printer is on and is connected to a working phone line.
  2. Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the
    scanner glass.
  3. From the printer control panel, press the Fax button.
  4. Enter a fax number, or press Address Book to select a number from the Speed Dial or Group Dial list.
  5. Press Color or Black to select a color or black-and-white fax.
  6. Press Start to send the fax job.
Source: Lexmark 5600-6600 Series Fax Guide
May 06, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Cant install fax software for lexmark x5495 aio printer.
1. Unplug the printer from the PC
2. Uninstall all the software related to the All-in -One ( that is on the PC)
3. Connect the All-in-One again then follow the software instructions for reinstalling the printer.
From the instruction manual:
Sending a fax
Entering a fax number
1 From the control panel, press Fax Mode.
2 Enter a fax number using:
The text box Enter a fax number using the keypad.
Notes:
• You can include a calling card number as part of the fax number.
• Enter a maximum of 64 digits in a fax number.
• Press Pause / Redial to insert a three-second pause in a number you
are entering to wait for an outside line or get through an automated
answering system.
Speed Dial or Group Dial a Press Phone Book.
b Enter Speed Dial and/or Group Dial numbers.
• Press or repeatedly until the Speed Dial or Group Dial
number you want appears.
• Use the keypad to enter the number of the Speed Dial entry (1–
89) or Group Dial entry (90–99).
Notes:
• For instructions on how to add Speed Dial or Group Dial numbers
using the computer, see “Setting up Speed Dial” on page 118.
using the control panel, see “Using the Phone Book” on
page 108.
3 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 2, using any combination of the previous methods, until a maximum of 30 fax numbers have
been entered.
Sending a fax using the software
You can scan a document to the computer and then fax it to someone using the software.
1 Load an original document facedown in the Automatic Document Feeder (ADF).
2 From the desktop, double-click the Productivity Studio icon.
3 From the right pane of the Welcome Screen, click Fax.
4 Select the Document option.
5 Click Start.
6 Enter the recipient information, and then click Next.
Note: A fax number can include up to 64 numbers, commas, periods, spaces, and/or these symbols: * # + - ( ).
Faxing
103
7 Enter the cover page information, and then click Next.
8 If there are any additional documents that you want to send with your fax, add these now, and then click Next.
9 To send your fax:
• Immediately—Select the Send now option.
• At a scheduled time:
a Select the Delay sending until option.
b Set a time and date.
10 If you want a paper copy of your fax, select Print a copy of your fax.
11 Click Send.
Sending a fax using the control panel
1 Make sure the printer is on.
2 Load an original document facedown into the ADF or on the scanner glass.
Note: Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
clippings) into the ADF. Place these items on the scanner glass.
3 From the control panel, press Fax Mode.
4 Enter a fax number or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
information, see “Entering a fax number” on page 103.
Note: To set up Speed Dial, see “Setting up Speed Dial” on page 118.
5 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 4 and press until a maximum of 30 fax numbers have been entered.
6 Press Start Color or Start Black.
Sending a fax while listening to a call (On Hook Dial)
The manual dialing feature lets you dial a telephone number while listening to the call through a speaker on the
printer. It is useful when you must navigate an automated answering system or enter a calling card number before
sending your fax.
2 Press .
3 Press or repeatedly until On Hook Dial appears, and then press . You can now hear the dial tone of
the telephone line.
4 Enter a fax number. For more information, see the related topic, “Entering a fax number.”
Note: Press the keypad numbers to use an automated answering system.
5 Press Start Color or Start Black.
Faxing
104
Sending a broadcast fax at a scheduled time
You can send a fax to a combination of up to 30 people or groups at a time you choose.
1 Load an original document facedown into the ADF or on the scanner glass.
2 From the control panel, press Fax Mode.
3 Press .
4 Press or repeatedly until Delay Fax appears.
5 Press .
6 Press or repeatedly until Delay Until appears.
7 Press .
8 Enter the time you want to send the fax.
9 Press .
10 If the printer is not set to the 24 hour mode, press or repeatedly to select AM or PM.
11 Press to save your settings.
12 Enter a fax number, or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
13 If needed, repeat step 12 and press until a maximum of 30 fax numbers have been entered.
14 Press Start Color or Start Black.
Note: At the designated time, the fax numbers are dialed and the fax is sent to all of the designated fax numbers. If
the fax transmission is unsuccessful to any of the numbers on the broadcast list, the unsuccessful numbers will be
dialed again.
Receiving a fax
Receiving a fax manually
1 Make sure the Auto Answer light is off.
2 To receive the fax if you have not set up a manual answer code:
• Press Start Color or Start Black.
or
• Press * 9 * on the telephone after you answer it and hear fax tones.
3 To receive a fax if you have set up a manual answer code, enter the code on the telephone after you answer it
and hear fax tones.
Note: For information on how to set up a manual answer code, see the related topic, “Setting a fax manual answer
code.”
4 Hang up the telephone. The printer receives the fax.
Faxing
105
Apr 15, 2010 | Lexmark X5495 All-in-One &USB...
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Fax wont send only recieve
Please follow the steps given below:
From the control panel, press Copy Mode.
Press Menu.
Press left or right arrow button until Tools appears and then press Check.
Press left or right arrow button until Defaults appears and then press Check.
Press left or right arrow button until Set Defaults appears and then press Check.
Press left or right arrow button until Use Factory appears and press Check again. The factory defaults are now restored.
You will be prompted to set the language, country, date, time and time format, your fax number, and name on the All-In-One.
CAUTION! Reverting to the factory default settings will delete all the printer settings you selected, including Speed Dial and Group Dial numbers.
Next, try sending a fax and let me know the result.
Apr 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5150 all-in-one inkjet printer. trying to get the fax to work. i have dsl.
You may have to experiment to get the fax to work on DSL. Try these suggestions: press MENU, then scroll to:PRINT REPORTS. Scroll to HELP LIST and press SET BUTTON. Press START button to print HELP LIST. On the HELP LIST printout, locate the FAX MENU. Using a cell phone, call your fax and see if the fax answers. If not, try changing the following settings (change one setting, then call the fax with the cell and see if it answers, Make sure you set each changed setting back to what it was, until you find the right one.) try changing: RING DELAY, F/T RING TIME, EASY RECEIVE, OVERSEAS MODE. Also on the HELP LIST, find the INITIAL SETUP MENU. Select RECEIVE MODE, and try each option, again calling the fax with your cell until it answers.After you get the fax to answer calls from your cell, try sending and receiving with another fax, or use Brothers AUTOMATIC FAX-BACK SYSTEM, which will automatically send your fax a test printout when you call it. Just call 1-800-521-2846 from your fax machine, IT MAY BE ALREADY PROGRAMMED INTO YOUR MACHINES AUTO DIAL LIST, AUTO DIAL NUMBER 001..
Aug 16, 2008 | Lexmark Office Equipment & Supplies
Faxing
this is a standalone fax machine. check if u hav connected the tel line frm the wall to the line port on the printer & then try to send a fax. In fax mode press the option button & then press the arrow till u see on hook dial & chk if u have a dial tone.
May 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark F4270 Plain Paper Inkjet Fax Logo
182 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
