Question about Toshiba e-Studio120 Copier
Toshiba e-studio 150
My Toshiba e studio 150 copier doesn,t work. Everytime I turn it on, it says H , 4 (alterning these letter and number. Tell me what to do , please.
  • ricksho May 21, 2008
    please give detaIls to clear H4 error on toshiba estudio 150
  • mferland996 Aug 06, 2008
    HI
    I HAVE A E-STUDIO 150 WITH THE SAME PROBLEM H4 - COULD YOU TELL ME WHICH BUTTONS TO PUSH TO CLEAR PROBLEM
    THANKS MARLENE
  • 32 Answers
Hi you have a fuser problem. The fuser does not heatup normaly. Sometimes it can besolved with the following code. Enter Sim mode. "c" - Auto/text/photo - "c" - Auto/text/photo - 14 -start - 00 - start. To exit sim mode press clear all. Turn the machine off and on, check operation. If that does not work check the Termosters, termostats, and heater lamps and wiring harnes.
Hope it helps
Posted on Feb 19, 2008
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba e-studio error H-4
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} H4 Heat roller low temperature detection
Apr 28, 2010 | Toshiba e-STUDIO 150 All-In-One Laser...
Turning on and off the printer counter
I don't think you can as this is the only way to tell the age and usage for the supply changes.
Mar 24, 2010 | Toshiba COPIERS E-STUDIO 3100C Copier
The letter L and then the number 1 appears when we turn on Help
My my how does this work? You will charge me to solve the problem but if I solve it myself you wish me to tell you how. Do I charge you for my solution then ? It makes no sense to me.
I solved it by the way but I'll keep it to myself thanks.
Aug 31, 2009 | Toshiba e-Studio 161 Copier Copier
Can the toshiba e-studio 150 print double sided?
yes you can print double side manualy
first time print your lowaer cassate after print another side is your copier right single sheet pass print side
thank you
Tareq
Jul 31, 2009 | Toshiba e-STUDIO 150 All-In-One Laser...
Will not copy
Hello sir; Check all the door is perfect closed !!!
Jun 01, 2009 | Toshiba Estudio 200L Copier
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
Feb 19, 2008 | Toshiba e-Studio150 Copier
Toshiba printer e-studio 150
There is a small clear plastic circle under where the paper comes out, it has two positions, lock and unlock, sometimes when people grab the copies they bump it to lock, use a flash light and make sure its unlocked, you can also just remove it, it was there for shipping. L-codes = scanner lock problems, real cold conditions can cause the scanner greases to not allow the scanner to move fast enough, put the copier somewhere warm. Good Luck!!!
Jan 22, 2008 | Kyocera RI-3530 Black and White Copier
294 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
