I have a dual layer dvd burner which has developed aproblem where if i try to burn an ISO or create a dvd disk, before burning commences i get a message saying the drive has encountered adma driver error and crc errors. Can you help me with what to do. Contact me on peterparcej@yahoo.com.au
-   My DVD burner is a SAMSUNG SH- S202J dvd burner and since of late when i try to make an Audio CD halfway through while wrtting the CD it stops and I get the message Burn error DMA error,CRC error. What on earth causes this I've lost about 12 discs trying to solve this problm, but stil have not made any progress. PETER.R. at peterranasinghe@yahoo.com
-   peterranasin
Sep 09, 2008
-   Guest
May 27, 2008
-   We get dma drive error, crc error when the burning process is at a certain stage. There the burning process is failed.-   Guest
May 27, 2008
-   We get dma drive errors and crc errors when the burning process is going on. There the burning process is being failed-   Guest
Its a problem with the windows dma seting for drives. In "device manager", open properties for ur drive and your interface like IDE/ATA controller. There, you can check and change DMA Settings.
Allow max DMA. Do not disable DMA.
U can also check DMA setting on BIOS if ur bios supports it.
What is the power supply for the Norcent 5224pi-072 - I haven't had this connected since moving and...
(More)
What is the power supply for the Norcent 5224pi-072 - I haven't had this connected since moving and I had misplaced the Power adapter and found one that connects, but not sure its the correct one
