Question about Toshiba e-Studio150 Copier
Error code in E studio 150
Please, can you help me with error code H , 4 (alternating) in a Toshiba e-studio 150? Thank you...
  • 2 more comments
  • papa_dia May 19, 2008
    I have the same problem.
    how do you enter the SIM mode?
  • Anonymous Jun 18, 2008
    Where do I get the sim mode from.
  • Anonymous Jul 10, 2008
    just wanted to say thanks. this worked for me also.
  • Anonymous Mar 12, 2014
    I have a toshiba studio 720 and is given me error code CB80, can you guys help me out with this Thank You.
    Problem Solver:
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
Posted on Feb 20, 2008
I tried the solution clear, auto , clear and auto - then pressed 14
start - clear and then the printer worked ok
Posted on Aug 06, 2008
Please wait message on toshiba e studio 205
Hi Leonie.
Please allow me to try to help you.
The reason why you get the - please wait message on toshiba e studio 205, could be because the HDD has become corrupt. Another for this could be a fuser error.
You can find more answers to this issue -
Attached is a tutorial that might help you gain more insight into this issue.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Toshiba Office Equipment & Supplies
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
What is the solution for error code c26 on my toshiba e-studio 550 copier?
Hi how are you i hope you are well this is jack personal ID.. (
C26 Error is scanner error
please check the scanner unite
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
please check these all goods are working properly.
Best Regards,
Jul 02, 2010 | Toshiba E-STUDIO 550 Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba e-studio error H-4
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} H4 Heat roller low temperature detection
Apr 28, 2010 | Toshiba e-STUDIO 150 All-In-One Laser...
Toshiba e-studio 150, Problem H4
This is a fuser related error - the fuser is not warming up within a specified time frame. It could be the heater lamp or a thermostat/thermistor that is not working, possibly a bad fan. You can cancel the error code (hopefully the error does not come back) by going into sim mode. press the following keys one after the other "clear" "density select key" "clear" "density select key" then enter 14 and the copy start key. then restart the copier. If error code persists you could remove the fuser unit and look for any foreign matter inside the fuser. dirty thermistor or thermostat can cause this too.
Hope this helps
Apr 05, 2009 | Toshiba E-Studio 161 Copier
Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Mar 05, 2008 | Toshiba e-STUDIO 150 All-In-One Laser...
Hi you have a fuser problem. The fuser does not heatup normaly. Sometimes it can besolved with the following code. Enter Sim mode. "c" - Auto/text/photo - "c" - Auto/text/photo - 14 -start - 00 - start. To exit sim mode press clear all. Turn the machine off and on, check operation. If that does not work check the Termosters, termostats, and heater lamps and wiring harnes.
Hope it helps
Feb 19, 2008 | Toshiba e-Studio120 Copier
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
533 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
