Question about Thermasol SteamShower Mechanical Timer - 240 - SSMT-240 - N/A
24hr timer to 240v lighting receptical need the wire diagram
  • 12,061 Answers
As for the Contacts wiring, there are TWO,, One contact will be wired to the Supply and Power IN to the Timers Phase + power &, Phase + IN Contacts. There will be TWO wires on that Terminal. The Timers other Power in wire is Neutral neg, it is Common, and connected to Neutral.. The other side of the Contacts goes to the Pfase + side of the Load. There will be only ONE wire on that side going to the "Load". The LOAD goes to this "Other" side of the Timer Contacts, which are Normally Closed, the Other side of the contacts, as said, goes to the Phase + on the LOAD & of course, the other side of the LOAD goes to the Neutral.Common. Now the Timer has power all the time, and when the timer "Times Out" the connection to the "Load" will be "Broken" when the Contacts "Open". Be safe.
Posted on Feb 02, 2010
Led wiring diagram on 240V AC
Is Led 120V or 240V?
For 120V you need a neutral wire.
240V generally does not have neutral wire.
http://waterheatertimer.org/How-to-wire-240-volt-outlets.html#120-240
Gene
Aug 14, 2014 | Hardware & Accessories
How to wire model t10004 control panel intermatic inc? I am just looking for a picture of the wiring diagram. All I need to do is hook up a the wiring for the light.
T10004 control panel has 240V T104 timing mechanism.
1) You can use T104 timer to control 120volt light if you have a neutral wire:
http://waterheatertimer.org/images/T-104-control-120V-Load3-45.jpg
2) Lights are usually 120Volts with black hot wire and white neutral wire.
3) T104 timer is 240Volts with two hot wires L1 and L2 that can be white-black wires or red-black wires.
4) Open following link to see basic 120V and 240V circuits.
http://waterheatertimer.org/B220C.html
5) Open following link for T104 wiring options
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 17, 2011 | Intermatic T10004R - Pool-Spa Mechanical...
I'm confused about how to properly hook the wiring to the product below. Specifically where does the "neutral" wire attach. I have it all hooked up, but I'm not getting the full 220...
Your 240V wiring is not described clearly, and it sounds like you are confused about 240Volt circuits.
You posted under T104R indoor-outdoor 240volt timer:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
Typically a 240Volt cable is 2-wire with ground, and does not have a 'neutral'
A neutral is not necessary to complete 240V circuit.
If your 240Volt cable is a 3-wire with ground, then the neutral connects to terminal A on timer.
Open following links for specific T104 wiring diagrams plus illustration of 2-wire and 3-wire cables, and illustrations and explanation of difference between 120V and 240V circuits:
http://waterheatertimer.org/images/wire-ga-250.jpg
If you have 240Volt cable, then do not move clock motor wires.
The clock motor wires connect to terminals 1 and 3.
240V power from circuit breaker connects to same terminals.
Load wires connect to terminals 2 and 4.
If you are not getting 240V across terminals 1 and 3, then check circuit breaker.
240Volt circuit breaker can be tripped off on one leg, or bad on one side so you get 120V on one leg at timer, and then clock motor does not rotate dial.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Jul 03, 2011 | Intermatic T104R 208-277Volt 40-amp Timer...
Need wiring diagram for T104M 208-277v Mech. Time Time Switch
Here is the basic instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Below is a larger and better diagram of a 240V connection Terminal connections are White to White on 3 & 4 Black to Black on 1 & 2:
More info: http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
I am assuming you have the 240 VAC clock motor so the clock timer motor wires are connected to terminals 1 and 3.
If you only have the 120 VAC clock motor the wires will be connected across terminals 1 and 2.
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
I have a coleman powermate maxa 5000 er Generator. Model # PM0525202. The powercord plug came loose and burnt the plug and the receptical(240). I replaced the plug and receptical and I am not getting...
If this is the model I am thinking of, there are 3 outlets. One 240V (L1, L2, Neutral and Earth ground. Some models use a 3 terminal receptacle that combines Neutral and earth.), one 120V receptacle (L1, Neut, earth) and another 120V receptacle (L2, Neut, earth).
If you verified fuse and circuit breakers are good, turn on the generator and verify you get 120V on each of the two outlets. Measuring between the narrow blades of the two 120V outlets should be 240V.
***Shut off the generator.
With a test light or ohmmeter, check continuity from the earth terminal of 120V outlets to 240V outlet. Likewise for neutral (wider blade on 120V outlet). Lastly, check continuity from Narrow blade of each outlet to the 240V outlet.
I suspect that you miswired neutral and earth. On a 4 wire PLUG, it is customary to connect earth and neutral.
Work safely so you can give feedback.
Aug 30, 2017 | Coleman Electrical Supplies
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I need wiring diagram for Paragon 8154-20. The plastic board has melted
I think you have the 8145-20 240V
This is a time-initiated defrost timer
Paragon 8145 page
http://www.uni-line.com/modules/catalog/SearchResults.aspx?mode=productsearch&prodID=8145
Wiring for 8145
http://www.uni-line.com/images/docs/refrigeration-8140series-wiring.jpg
Wiring diagram shows both 120V and 240V
L1 L2 is 240V
L N is 120V
Website that explains defrost cycle
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 11, 2010 | Paragon 8145-20 Defrost Timer
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Aug 21, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
How do i wire a Paragon 4001-00 timer?
Link below has wiring diagrams for 4001-00 timers:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Manual with wiring diagram:
4001-00 is wiring diagram #1
There are 3 terminals 1 2 3
Black Hot wire from circuit breaker goes to terminal 1
Black wire to Load (light, fan, motor) goes to terminal 2
Whites wires connect to terminal 3
Aug 13, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
I have an Intermatic 24hr. 125V timer, I need the wiring diagram
It should be on the door. It's marked 'line' & 'load'. Line is un-switched coming in and 'load' is your output to your motor or whatever you're running.
Jun 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Thermasol SteamShower Mechanical Timer - 240 - SSMT-240 - N/A Logo
137 people viewed this question
Top Thermasol Electrical Supplies Experts
woodzowl307
Jim Goldsmith
Jim Goldsmith
Are you a Thermasol Electrical Supply Expert? Answer questions, earn points and help others
