Question about Epson LQ1170 Matrix Printer
Configer in lan
How to configer in lan as a normal printer epsonlq1150
    Sergeant:
  • 406 Answers
Connect/Intstall on a pc locally and share the printer. If u browse the network you will find this printer. Just right click and install the Printer.
Regards
Rafique
Posted on Feb 19, 2008
My brother laser will not reset back to factory defaults
If you are using the printer in a LAN or Wireless LAN, you must assign to it an IP address compatible with your network. You do that by opening the Web admin interface of your router and assigning to the printer an address that is still free. Try 192.168.1.178 but that depends on the default gateway (192.168.1.1) that you defined for your router.
Aug 02, 2012 | Brother Office Equipment & Supplies
Tip
EPSON Impact Printers on a Mac
Connection Type : USB or TCP/IP
Driver : EPSON 9-pin or 24-pin Series 1.3
(resident CUPS / PPD driver - provided by Apple)
(no official EPSON driver)
>USB direct connection - check System Profiler-> under USB connection
>Got to Print & Fax and add the printer using the above driver
>TCP/IP connection - LAN set-up for printer configuration
>download EPSONNet Config Utility from http://support.epson.com
>run app and it will locate the printer regardless of IP address
>config to taste - default user/pass (it's blank, just hit OK button)
*the EPSONNet Config Utility is also available for Windows
(it's a neat utility)
on Jun 15, 2008 | Epson DFX-9000 Matrix Printer
LAPTOP LGR40 CONFIG RD405-A , CDT3A2 LAN DRIVER & SOUND DRIVER NEED TO FAST PLEASE gcjeengar@gmail.com
Ok here I found an outside source for this laptop:
Windows Vista/7 Drivers: CLICK HERE
Windows XP Drivers: CLICK HERE
Best regards Luis!
Feb 17, 2012 | Computers & Internet
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
I cannot install my Epson workforce 600 and get it to accept the IP address for my cisco linksys E1000 router.
I actually own a workforce 600 printer... they are nice for photos... anyway, the following solution only applies if your router is configured as a DHCP Server... This is the default setting, so if you don't know, then it is probably is configured as a DHCP Server. So, First, plug your printer directly into the router (wired connection) Then, load all drivers and software onto your computer. There will be one program in particular that you want to use. It is called "EpsonNet Config". Open that program (it is located in start---> all Programs--->EpsonNet---> EpsonNet Config Vx ) If your printer does not show up, you must verify your network settings on the printer (First make sure your wireless is disabled in Setup ----> Network settings --->Wireless LAN setup ----> Disable.... Then, Setup ----> Network settings ---> general network setup ------> "Yes" ---> press"ok"----> "Auto" ---->press"ok"---->"yes") Now, go back to EpsonNet Config on your computer and click refresh (upper left hand corner). When your printer shows up, double click on it. In the left pane click on network---> basic (wireless). In the right pane, click enable wireless LAN, then type in your SSID (routers name). DO NOT CLICK TRANSMIT YET. Then, in the left pane, click "network ----> security". In the right pane, put in the appropriate security level and key for your router. This information you would have configured when you setup your router. Now... click transmit then "ok". Wait for the settings to transmit 100%. now you can remove the network cable... verify that EpsonNet Config still can see the printer. and you are good to go. I hope this helps.
Livingmentor
Mar 22, 2011 | Cisco Linksys E1000 WirelessN Broadband...
J4167A jetdirect card not ready LAN ERROR-OPEN
if it is recognizing the jet direct card then the card should be good, not sure if yor network is setup for using dhcp but I usually deal with manual settings on these cards. I'm sure you know what your doing but it doesnt hurt to bounce it off others anyway.
I'll assume you know how to access the eio settings for the jetdirect from the menu screen.
choose manual setup instead of dhcp and keep all the othr settings at default except these other 3
1. You'll need to assign a manual I.P. address
2. you'll need a subnet mask I.P
3. You'll need a default gateway...
If you have other printers online then the subnet mask and default gateway should match the other printers but the actuall printer I.P address will of course be different... Hopefully this will help you out, and if so please write this a FixYa!!
Jul 19, 2010 | HP LaserJet 4100n Printer
My hp 4250 printer makes multiple config sheets,,its set to the default of 1 copy (s)
Please perform Cold Reset and then upgrade the firwmare of the printer
HP LaserJet 4250 and 4350 Series Printers - Performing a Cold Reset NOTE: The Jetdirect LAN (such as the IP address of the printer) settings will be reset to defaults by this operation. Record LAN settings before resetting the printer. Reconfigure LAN settings after the reset if you are using a LAN connection). To avoid resetting the LAN settings disable the embedded Jetdirect before performing a Cold Reset by choosing the Disable LAN option from the choices available when you get to step 5 below. Note that after choosing to disable the LAN it is necessary to reboot the printer and then choose to perform the Cold Reset . During the power up sequence only one operation can be performed at a time. In this case, first disable the LAN, then reboot the printer and perform the Cold Reset followed by another reboot to reenable the LAN.
To perform a cold reset:
  1. Turn the printer power off.
  2. Power on the printer and watch for the memory count to begin.
  3. Hold down the SELECT (Checkmark) button, when you see the memory count begin.
  4. Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
  5. After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until COLD RESET appears on the display
  6. Press the SELECT (Checkmark) button. The printer performs a cold reset and then continues its power-on sequence.
  7. Check all I/O settings and reset any user-set printer configuration values. NOTE: Before the I/O (LAN) settings can be reset to their correct values the embedded Jetdirect must first be renabled to make those options visible and available on the control panel of the printer. Renable it in the control panel settings then reset them to their correct values.
Link to download firmware:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-14
Steps to upgrade:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&swItem=lj-25065-14&prodNameId=412158&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=3
Rgds,
Nikhil
Jul 21, 2009 | HP LaserJet 4250n Printer
I have a wirelell setup between my desktop and my laptop cannot get my lexmark 4200 to shw up on my lap top?
If printer has ethernet port connected to lan ports on router and through your laptops windows settings make printer a network printer by going to add a printer.The wizard will guide you through.Also make sure you install printer cd into laptop.
Aug 25, 2008 | Computers & Internet
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
