Question about Goldstar GR131CN Compact Refrigerator
Goldstar GR-141CGP My Goldstar Bar Fridge has a chemical smell coming out of it. Could this be a Freon leak? Because I thought Freon was oderless... I did complete;y clean out the fridge and it still gets cold. Should I be Worried? thanks
KOakaKO
  • 135 Answers
SOURCE: Fridge Smell
Wash it out with bleach. Nearly always solves this problem.
Posted on Aug 02, 2007
  • 25 Answers
SOURCE: Chemical smell from refridgerator
Most refrigerator use R22 freon and this stuf does not smell very much. Maybe there is some milk or blood comming from a leakink pack, that entered between interior panel joints. Try placing an opened Harm & Hammer soda box; this could catch the odors. If after a week or so, this did not resolved this issue, I one had to replace some mineral wool (insulation) that as been contaminated with rotten food.
Posted on Nov 24, 2007
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
22yooper
  • 828 Answers
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
All items stored in the refrigerator and freezer should be stored in sealed packaging. Frost free refrigerator operate with a very low humidity and will pick up odors from products. Somewhat of an ozone smell will be in some frozen foods. This is a normal condition. Deodorizing packs are available on the market to absorb odors. Baking soda does the job in most cases.
Posted on May 31, 2008
Illeagle
  • 525 Answers
SOURCE: goldstar small refrigerator
If this not a frost free unit, then, based on what little information you provided, I can only say...maybe. This can easily be diagnosed if you can tap into the sealed system and do a pressure test, this will determine if you need freon. Most manufacturers put a 5 year warranty on the sealed system.
Posted on Jun 15, 2008
Why does my fridge and freezer have a chemical smell?
What might cause a chemical smell coming from a ... - Ask.com
www.ask.com > Home & Garden > Appliances > Refrigerators & Freezers
Coolant leaks and the use of chemical based cleaners are common causes of achemical smell in the refrigerator. Immediate action is necessary if the cause of
Jul 27, 2015 | Frigidaire Refrigerators
Freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
Mar 27, 2012 | Samsung RF265AA Bottom Freezer French Door...
There is a bad chemical smell coming from the freezer and the ice maker. someone thinks it is a freon leak.
It is not a Freon leak Freon is odorless. You will have to try tracking down the odor but rest assured that it is not Freon.
Jun 17, 2011 | Kenmore Top Freezer Refrigerator
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
I have a 99 Dodge Intrepid 3.2.. The a/c is not working... Freon is good, compressor is ok, it smells terrible when on and coming out of vents... I was told it could be the drain pipe is stopped up? Can...
could be expansion vavle is stuck,the bad smell
if it smells like chemical smell could be freon leak
in ac core or if smell is like mould its dirt rotting leaves etc in air intake, remove grill under wipers and vacuum out.
Aug 03, 2009 | 1999 Dodge Intrepid
Chemical odor
Hi serena38,
I'm Harvey the Master Plumber.
Your question is: You have a sweet chemical odor in our boat cabin, it leaves a sweet taste in your mouth. You cannot find the source. The fridge does not work. You can smell the odor stronger when the A/C is turned on or when the boat is closed up with the A/C off. Help????
Great, I live on a boat! I can think of two reasons for this. The first and most likly is electrical. Look carefully at the components especially the capaciter, it's on or near the motor. If it is leaking or out gassing, replace it. Wire corrosion can cause a wire to slowly give off fumes. These kinds of problems are common on a boat so look very carefully i.e. testing meter is helpfull here. I've already expirienced this and it sure was hard to find. Less likely is a freon leak. You won't smell the freon itself but if the oil is a little burnt, that can be smelly indeed. You will need a special leak detector for that. Anyway my money is on the electrical.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Kenmore 53642 / 53644 Side by Side...
There is a smell coming from the back of the fridge freezer,its a funny smell,sometimes you can smell it inside the fridge too, it seems to get stronger when the fridge is cooling more(as its a frost free...
I presume you have a house hold fridge if so you could be smelling a freon leak. It is a repulsive smell and you would notice it more during the cooling cycle. Is there any oily film inside or on the back of the fridge if so that is another sign. If you have a Recreational Vehicle it will smell more like ammonia and have yellow residue
Aug 11, 2008 | Refrigerators
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
97 people viewed this question
Top Goldstar Refrigerators Experts
venugopal durairajan
Tom Chichester
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
