Question about Gateway FPD 1730 17 in. Flat Panel LCD Monitor
My fpd 1730 moniters brightness and contrast are terrible, and i cant get the controls to work
  • 732 Answers
Nonnie707, It is very possible that your monitor's internal or external (lay on floor) "switch-mode-power-supply" has a problem. Prove that your pc is working by connecting KNOWN GOOD monitor to your pc!!! If you are not electronics technician then you will need to question Gateway as to warranty service or possible swapout for a REFURBISHED unit if your unit is deemed as premature failure. May cost $ for swap. READ my FIXYA profile and that of other FIXYA TECH's (buddymc, budmrtn) for more options as to "what to do"!!! Remember, If very strange and weird things start to happen (occur) with "cold-cathode-fluorescent-lamp" backlit LCD display, the first place I would investigate would be the units "switch-mode-power-supply" Good luck with the repair. 12fixlouie
Posted on Feb 02, 2010
How do I Adjust contrast And sharpness
To adjust contrast and sharpness
1. Press osd button (on screen display)
2.Use the up and down arrows to highlight selection then press auto/set button
3. Use the arrow keys to adjust settings
4. When you have finished press the osd button to save and exit
Thank you for using fixya.
Jul 11, 2011 | Gateway FPD 1730 17 in. Flat Panel LCD...
I own an FPD1730 17 in. Flat Panel Monitor. My screen is dim and I'm unable to manually change the tints back to the way it was. I have tried autoset on my monitor screen but it changes back to dim and...
this a micro-controller issue and a tech need to replace components that regulate the voltage to the florescent tube that excite the LCD to give a picture. they are sometimes call a LCD controller. This is a main board problem.
May 02, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 16, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
My hp 1730 monitor remains black. I can faintly see the display, close-up, but it is close to black. I just tried it on my other computer and it still does not work
The screen finely went out and it cant display any more. is it old? do you leave it on alot?
The screen probably burnt out. Or you just have the contrast or brightness turned all the way down.
Check these
Dec 04, 2008 | HP Computers & Internet
Gateway FPD 1830 18.1 in. Flat Panel Problem
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Sep 11, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
No Power On at all
What it sounds like is the Power supply on your FPD is bad. If its making a High Pitch Sound, A circuit or piece of your power supply is failing. It would need to be replaced in order to get it working.
Suggestion.
You can repair this easily if you have another FPD 1730 lying around that doesnt work you can replace parts, but its best if they were made around the same time because certain models have 3 boards(video board, inverter, power supply) But most have two boards (power supply, video card)
They are easy to replace and maneuver if you want to give it a try. Open the FPD and see what kind you have. If anything you might be able to find a part online.
Good Luck,
I hope this helps
victorsinferno45
Jun 07, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Logo
113 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
