Question about Maytag PYE2300AY Electric Dryer
My Maytag dryer model # LDE7314ACE has been making a terrible noise. We think the belt is breaking. We have waited for a few months and now it is making an even louder noise. How can you get into this dryer so we can see what it needs? Is it a hard repair?
I have not yet found solution but my same make and model dryer is making a very loud, grinding(?) noise. The 1st 8-10 mins of the cycle(regardless of which cycle) it seems ok, then the noise begins and becomes deafening. I thought since it is a Maytag, it would be worth the cost of repair, but now question whether I need to purchase a replacement. ??
Posted on Oct 14, 2013
  • 254 Answers
Go to sears.com, click on parts and service upper right corner, click on parts, enter your model number it will list a parts breakdown/schematic this wy u can determine whhich parts are removable and how its put togetherr and also get part numbers and prices, shop around though prices might seem low but they get you on the shipping check any local appliances stores if any are avaialbe in your area....
I persoanlly would check the belt, the rollers, or an idler pulley,, also maybe any glides or seals if your model has any........replace any defective parts you find hope this helps good day let me know whut u find
Posted on Feb 02, 2010
How do I fix gas clothes dryer? It makes a terrible noise.
that is a sign the bearing are going out. letting drum rub the sides
Feb 25, 2015 | Maytag Dryers
My Maytag MDE9606AYW drum randomly decides to not start. I hit the push button and there is loud noise but the drum doesn't move. When it does start the loud noise happens but it is quickly replaced by...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 02, 2011 | Maytag MDE5806AY Electric Dryer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
Dryer is making rapid thumping noise after running about 20 minutes on the sensor cycle. I have to shut it off and wait till it cools down and then try again.
belt problem most likely. see if there is access hatch in back. open it and look to see if something is in/on the belt /pulley. get a trusted friend to ease the drum around by hand and see it there is a break in belt
Feb 03, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Motor smells on model lde7314ace
If the motor smell burnt it is going to burn up soon. Unfortunatly it is time to replace the motor if it is worth it. You may consider a new one. Once the motor goes you can guarante that something else will follow.
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Atlantis dryer
Why is Maytag Atlantis is not drying like it use to?
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Loud noise, I think the belt
Take front of dryer .. 2 clips one on each side of dryer front.. once you get front of u will be able to see belt and look to see how front drum support comes off... post if you need futher help
this is a link to some diagrams that may help u
http://www.pcappliancerepair.com/model-display.php
Oct 14, 2007 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
410 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
