Question about Haier HLH26ATBB 26 in. LCD Television
I put the cable in the cable socket but it still tells me there's no signal. this tv was given to me, so I don't have a manual or a remote.
    President:
  • 1,768 Answers
1.You can do a google search and there may be a user manual for download.
2.There may be a fee for the user manual but you will be able to find it
3. use the model No. to find it.
4. addressing the cable issue you may have a bad cable.
5. I not sure of the cable you have or the cable connection you are addressing. I will need more info that is, is it a HDMI cable, vga, rca??
6. Also you may not have the connectors seated properpy check this.
7. If this is an HDMI connector check to see if you have bent pins, if so the cable pin will need to be straightened or the cable replaced.
8. If the unit has as vga connector input you will be able to connect it to a computer with a HDMI adapter to the video card on your computer to see if you have a signal
9. try these steps
10.The last step is to contact the manufacturer or find where these LCD tv are purchased in your area and ask the store manager or tech support where they purchase these unit and ask to get a manual of information to talk to one of their techs.
Posted on Feb 02, 2010
    President:
  • 2,049 Answers
On your remote, look for the INPUT button.
Push it slowly once at a time. It will change the input your TV is looking for and the cable TV will come up.
I need to change the tv to HDMI
A puzzling question Seth
To change a television to HDMI, you just scroll through the Input choices using the remote until you get to the HDMI socket the 'signal' is connected to.
The TV is Sanyo? Why do you need a Phillips remote? Why do you have to format the television?
Direct TV is your television signal supplier which doesn't have a lot to do with anything :>) The box has an HDMI socket? You connect an HDMI cable to the HDMI socket on the television and I refer you to my first paragraph.
Dec 11, 2015 | Televison & Video
Why won't my TV accept the Av signal from my VCR?
A couple of possibilities. First a faulty cable or socket on either the TV or VCR. Next the VCR is plugged into the wrong AV connection.
Jul 24, 2013 | Televison & Video
JVC TV Blue screen No remote
To select the source you must have its remote control. There is no TV/AV source select button at the front panel of this TV.
Jan 04, 2013 | JVC AV-27530 27" TV
Tv or cable remote don't work on tv
Have the remote or remotes tested to be sure they are ok---failing that every set has a remote receiver inside that receives the infrared signal the remote sent---suspect number one is the remote receiver in your set.
Jul 17, 2012 | LG 32LH20 32 in. LCD HDTV
Remote doesn't work. have purchased after market units and they don't sync up either? What to do?
Return the tv universal remote where u bought it,get ur money back.If none of the tv univeral romote programming codes on the owner manual codes for ur tv make and model don't even work and don't have any responses for ur tv make and model functioning all.Try website like Remotes.com to buy the tv original remote or a very closed compatible clone one.
Sep 03, 2011 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
I have just been given an old sony 5.1ch class t amplifier surround system will it only work when i play a dvd or will it work when watching normal tv, as i don`t have a manual
Will work with normal TV as long as your tv signal is broadcast in surround, such as thru a cable or satellite provider. Otherwise it will default to standard stereo.
Aug 20, 2011 | Audio Players & Recorders
My tv does not respond to the remote and has to be turned off and on manually first , when it eventually comes on it is on channel that is not supported by our digital signal. I have tried to skip the...
If this set is still under warranty return it for repair/replace.
Do you have the correct remote for this tv ?
If it is correct you can do a quick check to see if it is putting out a signal. Turn on a digital camera and point the remote at the lens. Press the power button and others on the remote and watch for a flash on the camera lcd screen.
Check that the input signal cable on the back is on the correct socket. Disconnect the unused input cables.
Go into the menu and set the input signal source to match the connection on the back.
Scan in the stations.
(There may be signal interference causing the problem)
Are the channels found within reception range?
You can check your freeview broadcast coverage at;
http://www.freeview.co.uk/HD
Feb 08, 2011 | Televison & Video
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
Trying to set-up dvd
If non HD, just link a scart cable from rear of TV to rear of DVD, if HD use a HDMI cable , there will be a number next to the socket on the TV that you plug the cable in, select that number using the remote and away you go. (If dvd recorder, av 2 usualy sends a signal to the DVR for recording)
Could tell you more precise if you posted the make & model of units.
May 28, 2009 | Televison & Video
Mitsubishi TV model CY2525
as tv is old please replace it by new kit or whole pcb. now a days you get new pcb(CHINA MADE) at cheap rate with remote & mo of channals more.
Sep 26, 2007 | Televison & Video
Haier HLH26ATBB 26 in. LCD Television Logo
271 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
