Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My son's calculator is locked up and we can not get any of the buttons to respond. I tried replacing the batteries and resetting it but can't get it to work.
    Problem Solver:
  • 5 Answers
Beta ko do thapar do khul jayega
Posted on Feb 12, 2010
Why is it that All the numbers are not responding except 1 2 and ?
TI 84 Plus Keypad not functioning - Cemetech ' Forum ' Calculator ...
www.cemetech.net > ... > Calculator Hardware
Mar 24, 2013 - Gryphon; Newbie (Posts: 2); Newbie ... My TI84+ will turn on when the on button is pressed, but no other ... i had the same problems but i had a problem with the os maby you can send a new os. at my calc is now all working Very Happy. new projekts (basic): c-compiler 1% / mylib 3% / ultimative gaming lib ...
HP 12c Calculator - Resetting the Calculator - HP Customer ...
support.hp.com/us-en/document/bpia5202
Sometimes a calculator will lock up or will not respond correctly. ... With thiscalculator, there are two options for draining the capacitor. The option to use is ... A paperclip reset can be performed on all HP 12C calculators with serial numbers before CN11500001. This will ... These calculators will have one CR2032 battery.
[PDF]Using the Canon Printing Calculator - Gallery Los Olivos
www.gallerylosolivos.com/Using-Calculator.pdf
Jan 31, 2016 | Office Equipment & Supplies
EL9300 not responding after a battery change. Only a down arrow is displayed on screen on top of screen
Just had this EXACT problem on a Sharp EL-9200C. I got the down arrow to go away and then the calculator functioned like normal. Here's how: I got a ball point pen and rapidly activated the reset button on the back, then rapidly pressing the CL key... probably about 45-50 times, but eventually it cleared all the memory out and the calc was able to boot up. This was after replacing the batteries multiple times and trying every key and every 2ndF key. I feel like the master of the universe now!
Mar 07, 2015 | Sharp El-9200c Scientific Graphing...
My ti-84 turns on but when i press any of the buttons it does not respond. Also the batteries are brand new. What do i do?
you need hard reset through the computer
if you can connect to the computer look what application is locking the Calculator
hope it will help
Oct 13, 2010 | Texas Instruments TI-84 Plus Calculator
The calculator appears to be frozen; none of the buttons respond; the display only shows "Ans" with a little 2 above and to the right of it, making it look like Ans is squared and then a blinking cursor
If pressing CLEAR doesn't get rid of it, try resetting the calculator. Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
Sep 09, 2010 | Texas Instruments TI-84 Plus Calculator
Locked
If the calculator has locked up you should perform a reset.
  1. Press and hold the [C] (ON/OFF) key
  2. Press and hold the [LN] key (third key from the left on the top row).
  3. Release both keys simultaneously. T
  4. The calculator should display "0.00" (if the number of decimal places is set to two.)
If that does not bring it to life you should perform a full memory reset
  1. Press and hold the [C] (ON/OFF) key.
  2. Press and hold the first key from the left ( the Square root x key) and the first key from the right (the SIGMA+ key ) on the top row.
  3. Release all three keys at the same time.
  4. Calculator should display "ALL CLr".
  5. To clear the message press the [C] (ON/OFF).
  6. The calculator should display "0.00."
If the calculator does not respond as expected,
  • Remove the batteries, and
  • with a metallic coin (and what coin is not metallica) short-circuit the calculator's electrical terminals.
  • Maintain the coin for about ten seconds.
  • Replace the batteries (preferably fresh ones) respecting the diagram inside battery compartment.
  • The Calculator should display "ALL CLr".
  • To clear the message press the [C] (ON/OFF).
  • The calculator should display "0.00."
If the calculator does not respond to the foregoing procedures, remove the batteries and leave them out of the calculator for 24 to 48 hours to drain capacitors.
If it continues to malfunction, it will need to be repaired. One repair shop in Pennsylvania, USA has a website at http://www.fixthatcalc.com. You should contact them.
Apr 11, 2010 | HP 20s Calculator
How to fix a none responsive button in hp 35s calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
I have a TI-83 that hasn't been used for a couple of years. I replaced tha 4 AAA batteries, turned on the calculator, but the screen just displayed one horizontal black line. I couldn't get it to respond...
Hope is what keeps the world turning.
Clean the electrical terminals even if they seem shiny. Use a clean eraser tip of a pencil.
Insert the main batteries.
If you see the line again, press [CLEAR] to see if it disappears.
Try resetting the RAM by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset] [ENTER][ENTER].
If screen is too light or too dark, adjust the contrast:
Press [2nd] key and release it
Press and HOLD Arrow (UP to darken, or DOWN to lighten) the screen.
If that does not solve the problem you may have to force the calculator to boot up. Details are in the article . Read the part on Ti83Plus family.
The article contains links to additional articles.
Hope it helps.
Oct 29, 2009 | Texas Instruments TI-83 Plus Calculator
How do I reset a TI83 Plus that reads, "Waiting...Please install calculator software now." It seems to be locked because it does not respond to anything that I type into it. I connected this...
Wow..., THAT is something I have never seen happen before, but to reset it hold the clear button while simultaneously taking out the batteries, let go of the clear button and put the batteries back in and volá (pardon the French)
May 06, 2009 | Texas Instruments TI-83 Plus Calculator
HP 20S Calculator
If it continues to malfunction, it will need to be repaired. One repair shop in Pennsylvania, USA has a website at http://www.fixthatcalc.com Here is the link . You should contact them.
Hope it helps.
Thank you for rating the solution.
Sep 03, 2008 | HP 20s Calculator
Turns on but does not respond to buttons
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem. If not, contact the guys over at Texas Instruments for replacement parts if you need them.
Mar 12, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
229 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
