Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer. F2143 Hot smell and drum stopped. took apart belt looks good, but the motor will move but with great turning pressure. Can I lubricate the motor and if now how do I replace? Gordon
  • 1,531 Answers
No the motor can not be lubricated.
the blower wheel can be removed by usin a socket on the front nut and a wrench on the flat spots of the motor shaft .
then remove the clips that hold the motor down and you should be able to remove the motor.
you also need to check the tension pulley and make sure it is not seized up.
Posted on Feb 02, 2010
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
Maytag Neptune Dryer MDE3000AYW. Replaced pulley and arm (pulley was seized to it), rear drum wheels, front drum glides, belt. Cleaned throughly inside. Worked like a charm for about 6 loads. Went to hit...
I'm guessing that your belt my have been misaligned, which means, no problem!
But, I recently had a machine that had a motor that would not turn, only hummed. I vacuumed the lint, then blew the lint out of the motor with a compressor, and vacuumed again. It still needed a push start to get the motor turning, but it starts on its own, now. So, if you have a lot of lint buildup, it can eventually stop the motor
Mar 06, 2017 | Maytag Dryers
My frig. agq600fs gas dryer drum will not turn.
Good bet it's the motor!
Disconnect electric plug.
Have to get access to back of the dryer, remove a few screws.
Look at motor and belt, motors sometimes over heat - Burn Up.
Motor could be replaced, depending on the age and how long you have had it!
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Dryer makes noise that sounds like tumbling glass and smells hot
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 19, 2010 | GE DBSR453EBWW Electric Dryer
Dryer is 10 years old, electric, and this is the first problem with the unit. Dryer was working, when another load was put in, it started and then stopped. It would not start again? I could smell a burning...
try and turn the drum by hand at the same time you are trying to start the dryer if it runs then you have a problem with you motor it may be dirty with lint and needs to be cleaned or the start windings have gone bad and needs to be replaced
Feb 23, 2010 | Frigidaire Electric Dryer
FRIGIDAIRE GLEQ2152ES0 DRYER DRUM WILL NOT TURN
You need to check the motor isn't bad which is possible. All of what you have stated is possible. You are going to have to check out each and every one until you find it. But all three can cause it.
Apr 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Jan 25, 2009 | Frigidaire GLER642A Electric Dryer
Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
Dec 21, 2008 | Whirlpool LER4634J Electric Dryer
GE Electric Dryer Older model
it could be the motor capacitor. to check, turn on and carefully give the drum a push in the direction of rotation. if the drum picks up speed and goea ok, then the motor capacitor is faulty. cheap part
Jun 26, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
149 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
