Question about Whirlpool Ovens
Erroe code f1e2 - Whirlpool Ovens
  • 254 Answers
Locare your model number and post it sometimes its on the frame under a drawer if u ahve a drawer if not check inside the oven for a sticker or tag,, or possibly if you top lifts up for cleaning check their..
this is a generic f1-e2 code listing it lists it as a control board problem and to replace the control board....
control boards vary but can be between usally 200-400 dollars so i would see waht is cost effective whether to just replace the unit depending on how old it is because after service call usually another 100 dolllars and labor to put it in u could be close to the price of a new range hope this helps
Posted on Feb 02, 2010
Code F1E2 on whirlpool electric range mean
This is not a good code and usually means the electronic control will need replacing. Try disconnecting the power for a couple minutes and if the error comes back, the control is bad and will need replacing.
Sep 27, 2014 | Whirlpool RBS275PD Electric Single Oven
Co1 erroe code distinctive wall oven what is problem
According to your model number this code means Shorted or stuck key. Your keypad needs to be replaced. Good Luck
Aug 07, 2014 | Dacor Distinctive DO130 30" Single...
Erroe code f7
F7 means Stuck Button
- Function pad button stuck or
- Bad clock. Try to free stuck button or
- Replace Electronic Range Control (ERC).
Someone mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser.
It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 09, 2011 | Ovens
Please help erro code 00E on sanussi multi oven model is as per book zsm 705 w/k ps i am in australia
This code is an open circuit of the Oven sensor which needs replacing.
To access this remove the top panel and left hand side panel,detach the wiring connector from the sensor.Detach the sensor from the clips on the inside of the oven.Remove the sensor from the rear of the oven.When replacing the sensor, make sure it is securely held in position by both clips.
Hope this helps.
May 21, 2010 | Ovens
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
F7 erroe code on my GE oven
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Sep 01, 2009 | GE Profile JTP56 Electric Double Oven
MAYTAG GLASS TOP STOVE
I had the same problem, all you do is hold the clock button down for about 5 seconds.
Dec 05, 2007 | Ovens
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Ovens Logo
97 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
