Question about Dual XINBP212 Car Subwoofer
Dual xinbp 2-12s not in the original box...
Hi, I had 2-12s but 1 is blown, I was going to put the other 12 in a box by its self cause it still works. I was wondering would it sound better in a sealed box or a ported box....type me back thank you.....
Bose lifestyle 12 no power
check inside for a blown fuse.also there may be a problem with the board it's self.check to see if youre getting power through the cord and then go from there.check something electrical in the same place you plug in your bose such as a hair dryer and see if that works.if it doesn't check your fuse box for a blown fuse.
May 22, 2012 | Bose Lifestyle 12 System
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
How do i install a dual xinbp-210 car subwoofer with a pyle amp and stock stereo in a 2005 nissan altima
you can buy an adapter that splices into your back speakers and converts for your amp.
Oct 26, 2009 | Dual XINBP-210 Car Subwoofer
Smoke was coming out of my subs and it was alot.
Open the sub box and see what it looks like before you go purchasing stuff with no problem for certain. You may have had wires touch and they will smoke. Also try connecting a different speaker to the amp and see if it works. this lets you know if the amp/speaker is working or not
Sep 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
BMW X5 Original Stuck Window
hi there
there are three things that would cause this problem
1. the window motor is bad
2. the fuse that controls the window is blown
3. most common is the window switch its self
this is the most common cause
if the motor was going out it would make a noise or go down very slow but going down is easier then up so thats what makes me think switch or fuse
don
Jul 04, 2009 | 2002 BMW 5 Series
Car stereo not working after installing
i had the same problem with mines it came on the shut off then i looked at the fuse and the radio blown the 10fuse i had in it then i put another 10 in it and the radio didnt come one at all finnaly i looked it up on the internet and it said i needed 11-19 i think so i put a 15fuse in the line and it worked fine
May 22, 2009 | Dual Electronics XDM7510 CD Player
The lights are off
Do you have a 12 volt power running to the lighting plug? That enclosure requires a seperate 12 volt power line in order to make the lights come on.
Jul 16, 2008 | Dual XINBP-210 Car Subwoofer
Hooking up a sub woofer
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
take a look there and it should give you everything you need and show you the different options for the different ohm loads. Remember... don't go below 4 ohms on those. Above is ok, below is not.
Jan 10, 2008 | Dual XINBP-210 Car Subwoofer
Not even static?!
if the flex wires are atached from the cone then the coil is disconnected.hit me up if you need more info.
Aug 09, 2007 | Dual XINBP-210 Car Subwoofer
Dual XINBP212 Car Subwoofer Logo
129 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
