Question about Cooktops
I have an AEG gas cootop but the knobs are worn
I have an AEG 6310DK gas cootop but the knobs are worn and i can't find anywhere.
A company called Bromic/Ambro supplies the best knobs. You can contact them on their website. This of course should be done only if the knobs are out of warranty. Or else contact hemantk@bromic.com.au. I think he is the sales engineer over there.
Posted on Feb 03, 2010
Is there any way to replace numbers etc that have worn off a gas cook top?
several:
1. If its sill available replace the control knobs.
2.Contact the manufacturer.
3. There are pens that are fine point acrylic paint that you could write them on with manually. There available at Walmart or any craft supplier.
4. Possibly vinyl graphics.
Jun 04, 2017 | Cooktops
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
One igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
Jul 14, 2010 | AEG 34942G-M Gas Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Miele gas cootop
What is the entire model # of the cooktop?  Should be a sticker on the bottom of the unit.
Oct 15, 2007 | Cooktops
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
One knob does not light and its ignition is not working. The rest of the knobs are working fine. Thanks
You have ignitor issues. If there is a spark on your other burners but not this one it is the wiring, the switch (if the sparking doesn't happen with this burner) or the gap is worn. If these hints don't get you to an answer...get a pro in to look at this.
Dec 31, 2006 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Cooktops Logo
88 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
