<p>The iPod Touch iTunes Store requires an active Wi-Fi or
cellular connection service to work properly. Unlike the iPhone, Apple iPod
Touch has no ability to mobile data services. If you connect to the iTunes
Store on your iPod Touch, you must first connect to a wireless Internet
network. This allows you to enter the iTunes Store on iPod Touch and make
purchases directly on your handheld. <br />
<p><br />
<p>1. Click the "Settings" button on your home
screen. <br />
<p><br />
<p>2. Select "Wi-Fi." The Wi-Fi page loads. Slide the
switch to "On" position. A list of taxes Wi-Fi networks <br />
<p><br />
<p>3. Select the Wi-Fi is connecting. If you are prompted for
the network password, enter the password and click "Join." The iPod
Touch connects to Wi-Fi network you selected. <br />
<p><br />
<p>4. Tap "Settings" back arrow on the toolbar at the
top of the screen to return to the main Settings menu. <br />
<p><br />
<p>5. 'Store' select the tab. The page is loading Store. Touch
the "Sign In" button. <br />
<p><br />
<p>6. Select "Use existing Apple ID" from the options
pop-up windows that appear. <br />
<p><br />
<p>7. Enter your email address Apple ID and password in the
"Email" and "Password" field of the prompt signal. <br />
<p><br />
<p>8. Click the "OK" in demand for the iPod Touch
connected to your iTunes Store account<br />
Connects over the last Wi-Fi network you used that's available.
If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon () next to them.
Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon () in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
Turn Wi-Fi on or off. Choose Settings > Wi-Fi and turn Wi-Fi on or off.
Set iPod touch to ask if you want to join a new Wi-Fi network. When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon ().
If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
Join a Wi-Fi network manually. Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow () next to a network you've joined before. Then tap "Forget this Network."
Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks). Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
Adjust settings to connect to a Wi-Fi network Choose Wi-Fi, then tap the arrow () next to a network.
DEAR SIR,
YOUR IPOD TOUCH IS NOT CONNECTING, IT MAY B THE REASON THAT UR IPOD'S WI-FI IS NOT WORKING OR SETTINGS OF WI-FI ARE NOT CORRECTLY DONE. KINDLY DO SETTINGS PROPERLY, IF NOT, THEN CHECK THAT YOUR ROUTER IS PROCESSING YOUR WI-FI OR NOT.
THANKS.
PLEASE RATE ME...
<p>Apple iPod touch Wi-Fi reception without using a computer.
The device has a built-in 802.11 Wi-Fi receiver, which means that access to the
Internet via a WiFi router that is in range. When connected to a WiFi signal on
your iPod touch, you may be prompted for a password if you must know the
password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not
require a password. <br />
<p><br />
<p>1. Press the "Home" button of your iPod touch and
move the cursor to the right on the device. Enter the unlock code if you have
programmed. <br />
<p><br />
<p>2. Touch the "Settings" icon on the home screen of
the iPod touch Settings menu. <br />
<p><br />
<p>3. Play the "Wi-Fi" Network access to the names of
all upcoming Wi-Fi to see. <br />
<p><br />
<p>4. Tap the name of a Wi-Fi to connect. If the network requires
a password, you will be prompted to enter the password. <br />
<p><br />
<p>5. Touch "Join" to complete the connection. Now
you can use any Internet-related programs on your iPod touch. <br />
<p>One of the most useful features of the iPod Touch is the
ability to use the Internet through a WiFi connection if you have a wireless
home network and within range of your router, you can access the Internet via
your iPod with ease. If you're in public, you can use the free wireless
internet businesses such as hotels, cafes and airports. If you are not in a
Wi-Fi zone, will warn you that your iPod will not be able to get online. When
this happens, then you need to move to an area that has Wi-Fi <br />
<p><br />
<p>1. Confirm your wireless connection is configured correctly
by checking if you can get online on your home computer. If your router is not
configured correctly, you will not be able to use their access to Wi-Fi with
your iPod. <br />
<p>2. Go to a place where you know Wi-Fi is available. In urban
areas, Wi-Fi is available in many businesses and families. Press the
"Settings" icon on your iPod, click on "Wi-Fi" to search
for available networks in the area. If there are none that appear, confirming
the Wi-Fi icon at the top of the page is set to "On" instead of
"Off". If no network can see, you're in an area where there is Wi-Fi
available. <br />
<p><br />
<p>3. Click the name of an available Wi-Fi network and enter
the correct password. Sometimes you may not be able to access the network,
because you do not have the password. While companies such as pubs and hotels
to their networks without protection for the enjoyment of their patrons are
usually password protected networks. <br />
<p>IPod touch not only offers a music library on the road. It
also has Internet capabilities. The iPod touch can connect to wireless internet
connection available and browse the web using the Safari browser included on
the device. Typically, Wi-Fi capabilities automatically. But if your iPod touch
wi-fi is off, or if you activate it, you can do it using the Settings window. <br />
<p><br />
<p>1. Touch the "Settings" icon on the main screen of
the iPod touch. <br />
<p><br />
<p>2. Touch the option marked "Wi-Fi." <br />
<p><br />
<p>3. Touch the "On" next to the setting marked
"Wi-Fi." <br />
<p><br />
<p>4. Tap a wireless network list to connect. <br />
<p>The iPod Touch is a portable media player, game console and
personal information manager developed by Apple. The first generation iPod
Touch was released in 2007, the fourth current generation was launched in 2010
at the time of publication. Among other hardware features, the factory setting
of the iPod touch already has a wireless adapter 802.11b/g/n standards for all.
The operating system runs on the iPod touch is set at the factory to take full
advantage of this hardware. You can sign up for free Wi-Fi with iPod touch. <br />
<p><br />
<p>1. Tap "Settings," then "Wi-Fi." Push
the "Wi-Fi" control "ON". <br />
<p><br />
<p>2. Push the "Request for new connection" control
"ON". <br />
<p><br />
<p>3. Enter the radio band - usually at least 100 meters - the
Wi-Fi is connecting. IPod touch displays a message asking if your network that
detects the radio signal to connect. Answer "Yes". After a few
seconds, you will see the Wi-Fi icon in the status bar of the iPod touch; iPod
touch will be ready for the wireless network connection. <br />
<p>If you try to access the Internet to your iPod Touch, Wi-Fi
hotspot and only that will detect the device is marked with a padlock, which
means you need a password to use Join the network type. Ipod touch internet
access via Wi-Fi, allowing you to browse websites with the Safari application,
check your e-mail and free video calls with Face Time app. You need someone for
the password if you want a Wi-Fi closed. <br />
<p><br />
<p>1. Ask your department manager of the company computer
network password for the Wi-Fi when you use your iPod Touch to access the
Internet while at work. <br />
<p><br />
<p>2. Check the password for a printed receipt to a Wi-Fi
closed after making a purchase of a restaurant that offers Wi-Fi service to
paying customers. <br />
<p><br />
<p>3. Ask your neighbor for permission to your WiFi signal, if
you want to access the Internet via Wi-Fi network from your computer. If you
are on friendly terms, she would give him the password. <br />
<p><br />
<p>4. Go to decree or in a mall and ask for the password to
block Wi-Fi, so you can access the Internet while you shop. <br />
<p>Include network interface, the iPod Touch is equipped with a
wireless adapter that allows hardware to join Wi-Fi networks by default, an
iPod Touch love all Wi-Fi was never confirmed, this feature saves users the
reenter the work of key network authentication and other parameters. However,
in some cases, a user can have a Wi-Fi network to remove the memory of the iPod
touch - for example, when the network configuration has changed. You can also
prevent applications such as Safari Internet access. <br />
<p><br />
<p>1. Tap "Settings," then "Wi-Fi." <br />
<p><br />
<p>2. Research on Wi-Fi network that you want to delete the
list of networks remembered for iPod Touch. <br />
<p><br />
<p>3. Tap the blue arrow beside the network name and tap
"Forget this Network." At that moment, the iPod Touch lost all memory
you have connected to that network - past and configuration parameters. <br />
