Question about Dell Inspiron 6400 Notebook
Connecting to the printer via a local network
Unable to connect my laptop to printer via local network
  • Anonymous Feb 27, 2008
    Having a problem connecting my wireless laptop (ACER AMD Turion ( 1.9 GHz, 2 x 512 KB L2 cache) to my printer (Canon PIXMA MX 310).
    vespo2005@aol.com
    Sergeant:
  • 406 Answers
Check network settings, you can browse the network. If you have an static ip let me know.
Best regards
Rafique
Posted on Feb 19, 2008
Hi All, I am trying to connect Toshiba e-studio 207 via local network but unable to make it work.
Best way to Check is getca status page from your printer ,check the IP address that’s been assigned to your printer via dhcp from the router ,then just add the printer manually by creating a tcpip port with that op address
Oct 28, 2017 | Toshiba e-Studio 232 Black and White...
Hi, I just purchased a Xerox Work Centre 4118 for my office. I have Windows 7 Professional and am unable to Print via wireless. I receive a message that the Printer is offline. Would you be able to...
http://www.support.xerox.com/support/workcentre-4118/downloads/enus.html
The above links to the drivers page, but unfortunately, I do not see specific Windows 7 drivers for this printer. This means that older XP or the latest drivers from the year 2008 are used in emulation mode, maybe, for Windows 7.
Since this is not a 'new' printer, I gather, it will not guaranteed to work with Windows 7. However, I would try the link above for various drivers which may or may not work on this printer.
The fact that the Printer is shown to be offline, is a bad sign.
I read that the printer in question has the following connectivity:
Connectivity
But, that it doesn't support WiFi.
USB, Parallel, optional 10/100 BaseT Ethernet.
Jan 19, 2011 | Xerox WorkCentre 4118 Network Kit...
Unable to connect EpsonTX710W Printer viaNetGear DG384
On your Laptop go to Control Panel-> Printers-> and then add printer. Select the option of network printer and search for your printer. If found add it.
Or Else check the ip of printer from ports tab in printer properties on desktop computer ans search your printer with ip address on Laptop.
Jun 01, 2010 | NetGear DG834G Router
Unable to connect to the laptop computers
dear Sure there is, but it's supposed to connect via a LAN switch. Since it worked at your old place, did you miss a step? Was the printer plugged into a router and the computer also plugged into the same router?
Start with the wired network setup section in the quick start guide. It might give you an idea on what to do http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_490CW_EN_1578.PDF
Thanks.
May 07, 2010 | Brother MFC 490cw Color Inkjet...
Wireless connection
maybe you dont have internet connection..you are only connected on local network...check your router setting or reboot your modem and router
Mar 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Mar 18, 2008 | Dell 3000cn Laser Printer
Wireless prob
Open the Printers and Faxes folder on the computer that was connected to your printer.
To open the Printers and Faxes folder
• Click Start and then click Control Panel.
• Click Printers and Other Hardware, and then click Printers and Faxes.
• In the Printers and Faxes folder, Click the printer's icon and, in the tasks pane, Click Share This Printer.
• Open the printer's Properties dialog box, and clicked on the Sharing tab.
• Click Share Name, and then click OK.
That's it—the printer is immediately available for other computers to use.
Now that you have a network printer, Your was ready to connect to it and print from other computers on the network.
To connect to the printer:
• Open Control Panel, and clicked Printers and Other Hardware.
• Click Add a Printer.
• Instead of adding a local printer, click Printer Connection and then browse the network for the printer.
Jan 12, 2008 | Acer TravelMate 2300 Notebook
Dell Inspiron 6400 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
