Question about Denon AVR-2809CI
Denon 2809 receiver makes loud audio pop and then no hdmi output
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Posted on Feb 17, 2008
marsrover
  • 682 Answers
SOURCE: Mac Mini and Denon 3801
http://www.retrevo.com/samples/Denon-Receiver-manuals.html
Posted on Aug 09, 2008
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
  • 899 Answers
SOURCE: static on all audio output
the bigger IC is how the amp IC will look like
3bd6cf1.jpg I would try and get it in , because it will end up quiting and will cause more dammage
Posted on Apr 01, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
How to hook up a denon avr -1706 receiver To a lg smart tv
If you are tuning in TV stations with the TV set, you will need either an optical or a coaxial audio cable to go from the digital audio out of the TV to a digital audio in on the receiver. This setup should give you 5.1 Dolby digital sound. You can also use a pair of red and white rca cables, but you will only have 2 channel sound. You may need to set the TV to output the audio to external speakers. You will need to set the receiver to the input the TV audio is connected to.
If you want to watch Sat or Cable, you probably need a couple of HDMI cables. One HDMI cable will go from the output of the Sat/Cable box to the appropriate HDMI input on the receiver. The second HDMI cable will go from the Monitor Out on the receiver to an HDMI Input on the TV. You may need to set the receiver to output HDMI audio from the receiver, and not the TV. You will need to set the TV to the HDMI Input you connected to on the TV. You will also need to set the receiver to the input the Sat/Cable box is connected to.
Details of both of these setups should be covered in the receiver and the TV manuals. Refer to them for the detailed connections and settings you need to make.
Good Luck!
Mar 02, 2015 | Denon Audio Players & Recorders
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
We have a DVD components to our AVR-2307CI Denon receiver and then is outputted through the HDM1 1 out connection. The message 'not supported mode' comes up. Please help to tell me what I am doing wrong....
HDMI1 on the receiver is an input not an output. Make sure your TV connected to HDMI MONITOR OUT. On HDMI setup, check if analog to HDMI convert is ON, Color Space set to YCbCr. If you have more problem refer to page 54 of the owner's manual.
Nov 23, 2009 | Denon AVR588 Receiver
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Feb 15, 2009 | Denon AVR-4806 Receiver
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Nov 24, 2008 | Denon Audio Players & Recorders
Poping in speakers
Same issue with my AVR-589...2-15 minutes after sound is playing (via TV or DVD). I checked all wires and speakers. Even reconfigured to audio only (analog) coming in, same issue. Put my old Denon receiver in and the problem disappears...possible overheating issue with this new unit?
Dec 22, 2007 | Denon AVR-3806 Receiver
Denon AVR-2809CI Logo
79 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
