Question about Fuji FinePix S5000 Digital Camera
Hi, the camera worked fine for years and one day the camera stopped "seeing". The 1" screen works fine but the camera doesn't see light or the scene and will not capture images. It seems like it wants to work but doesn't. It acts like I left the lens cover on it. dave
  • 244 Answers
This is the most common problem with digital cameras.
The shutter is stuck in the closed position. This is most likely due to moisture residue built up over time on the shutter leafs. You will need to have the camera serviced to have either a new lens unit or have this one stripped down and cleaned.
Posted on Feb 02, 2010
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
White Screen
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in the first case the only solution is the replacement of the CCD.
Please click HERE
And in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Click HERE for the manual.
Main support number: 800-755-3854
I hope you are satisfied with my solution..
Goodluck..
Feb 21, 2008 | Fuji FinePix S5000 Digital Camera
READ MENUS FINE, LENS OPERATES FINE, OTHER STORED PHOTOS READ GOOD, BUT CAMERA SHOOTS ONLY BLACK FRAMES, NO SCREEN IMAGES WHEN SETTING UP A SHOT. WHEN HELD UP TO THE LIGHT THROUGH THE LENS, A FAINT GRAY...
woowww man i think youv got a lot probs with you camera,mainly if there is a a black frame in you screen i think your screen monitor is damaged so ull have to replace it...... and da black frames is a fault in da camera itself.according to wot i understand i think the shutter speed is not corresponding with da software in da camera um sorry but dese repairs are gonna cost ya.... best tin is to give it to a repair shop or service personnel for further clarification
May 30, 2011 | Cameras
CAN YOU PLEASE EXPLAIN TO TO ME WHAT IS EV COMPENSATION AND HOW DOES IT WORK
EV compensation is "Exposure Value compensation". The camera contains an exposure meter which determines how much light is on the scene and sets the exposure appropriately. However, this meter does not know WHAT you're taking a picture of, nor does it know what effect you're going for. The best it can do is to assume you're taking a picture of an "average" scene and want it to be of "average" brightness. It does this by assuming the scene is "middle gray," halfway between black and white. Most of the time this works fine, because most scenes are, well, average.
However, this is not always the case. Suppose you're taking a picture of a white dog playing in the snow. Almost everything in the scene is bright white, but the camera doesn't know that. It tries to make the scene middle gray, and the result is that you get a gray dog playing in gray snow.
On the other hand, suppose you're taking a picture of a black cat sleeping on the hood of a black car. Here everything is black, but the camera doesn't know it. It tries to make an average scene, resulting in a gray cat sleeping on a gray car.
EV compensation allows you to override the camera's exposure setting. In the first example, you'd want to add two or three stops (positive EV compensation) to force the camera to render the dog and snow as white instead of gray. In the second example, you'd want to subtract a stop or two (negative EV compensation) to render the cat black instead of gray.
How much EV compensation is correct? Well, that depends on the scene. With a digital camera, you can look at the picture and see whether the dog looks white or the cat looks black. Film photographers take lots of shot, using various levels of EV compensation, so that one of them would come out right.
Mar 19, 2011 | DXG Technology DXG-505V Digital Camera
My nikon D5000 monitor is dark and i have to look through the viewfinder to see the scene i want to take a picture of. monitor works fine to view taken pictures and in filming mode. why? and how can it be...
The Nikon D5000 must be set in "Live View" mode before you can use the rear monitor to take photos. There is a button that says "LV" to the right of the LCD screen that sets Live View to on or off.
Mar 09, 2011 | Nikon D5000 Digital Camera with 18-105mm...
I have a Panasonic DMC-LX2 digital camera, I'm based in the UK. Has worked fine for a couple of years, but 2 weeks ago, when powered up, none of the buttons work. Screen is illuminated, lens emerges OK,...
I just got identical situation today, and I have no clue at all. However, I figure that the camera is actually working busy like someone is holding the "UP" button continuously. To see this, power on your camera at any mode except the "Scene mode". After it's on, turn the mode select knob to "Scene mode". I saw my camera menu flashing like crazy. When you press any button, the menu should stop running. But once you don't press the button, the menu start running again.
Please let me know if you have any update.
Sep 21, 2010 | Cameras
May cam has a problem in taking pictures in day light and in any place with light the picture become so light and has a many white line too but getting picture at night or in low light place the picture...
It could be 1 of 2 issues:-
1) Make sure all your settings are on Auto and try again. It may be currently set to a specific scene setting which is distorting your photos.
2) It may require a firmware upgrade. That will involve going to the Samsung website, following links to support/downloads and checking to see if there's an update for your camera.
Apr 10, 2010 | Samsung Digimax S630 Digital Camera
My camera was working fine for about a year. Then one day i turned it on and the screen was black but it shows the grid and date and time also it shows the menu and the differnet scene selections. If i...
Take the camera andturn off the flash. Point it toward you and take a picture. Look in the lens to see if you see the shutter activate. If you dont see this work, then your shutter may very well be stuck.
There isn't really a home fix for it and the cost of having a professional repair it is just as much as a new camera.
If you do see the shutter activate please comment below and I will be more than happy to troubleshoot your problem further!
Cheers!
Feedback is appreciated!
Dec 31, 2009 | Olympus FE-310 Digital Camera
Ihave a fine pix z20. The LCD screen is not working. The camera still takes pictures fine and the card prints the pics fine but the screen is just white with a grey line through it. I forgot to register...
If you still have few days warranty, call Fuji at 1-800-800-3854 , select option 1 and register your product, or check the website. They will tell you if the camera is still on warranty.
Here also US website.
Fujifilm: Support & Contact Center
If you leave outside US see fuji website for contact:
Home | Fujifilm Global
FUJIFILM Australia
FUJIFILM Europe
Jul 27, 2009 | Fuji Cameras
JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Fuji FinePix S5000 Digital Camera Logo
170 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
