Question about Compaq ProLiant ML530 Server
Booting from cdrom
I installed scounixware 7.1.1 on above server. It keeps on rebuilding kernel ... for ever. To overcome the problem, I wish to reinstall from CD.
However, I am not able to do fresh installation from CDROM. Instead of starting fresh installation from CD, server accesses installed sco unixware and goes in loop of rebuilding kernel...
Pl help
anant_khadilkar@hotmail.com
  • 2 more comments
  • khadilkar Feb 27, 2008
    To,
    Tinker12.. Yes , I want to wipe the sytem clean. No data wish to save.
    To,
    Khadilkar. Pl give solution.
  • khadilkar Mar 03, 2008
    Helpful solution
  • William Cline May 11, 2010
    Do you want to wipe the system clean? And / or is there any data you wish to save?
    Problem Solver:
  • 6 Answers
Locate your copy of "SmartStart" (SS) for the proliant server. Boot into the Bios and check that the CDROM boots before the HD. Insert the CDROM Smartstart into the server and restart. When SS comes up you can use the array erase utility. Erase the array, reboot it and let it come up again with the SS disc. Create a new array, and choose the OS to install. Let it go all the way to create the partition and format. When it asks for the OS put in your disc and reboot. This should allow you to start over again. If you do not have the original copy of SS you may find one here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=344318&taskId=135&prodTypeId=18964&prodSeriesId=345557&lang=en&cc=us
Posted on Feb 28, 2008
To,
Posted on Feb 27, 2008
To,
To,
Server boot
ntldr is part of the Master boot Record (MBR) it is used in conjunction with other files to allow the OS to interact with the Kernel.
you can copy the MBR record but it is specific to each PC so your options are rebuild server or restore from a backup I would recommend back up as all additional settings will be applied still.
Dec 23, 2013 | Dell PowerEdge 750 Server
E machine T3120 hard drive sector bad no boot up
Replace Hard drive and Re-Install the Operating System.
Jan 07, 2013 | E-Machines T3120 PC Desktop
Black screen with cursor
Windows is corrupted or the hard drive has issues. If you have a backup cd recovery disc try it now, if that fails have the hardware tested for possible replacement.
Jul 27, 2012 | Toshiba Satellite L500 Series Notebook
Error message "load needed dlls for kernel"
1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer.
Mar 05, 2011 | Acer Computers & Internet
I have ML350 G3 Server SA 532 and 2 HDD SCSI, W2K. I want intall RAID 1 Can I help me???
unable to understand your question.
If you want to configure raid 1 and install OS freshly then follow these steps.
1) make ready all the required h/w.
2) Swith on the server.
3) when post starts reading SA532 controller press F8 button .
4) you will enter into Raid card bios.
5) select View to know any existing logical drive.
6) select Create logical drive,select both hdd's by pressing space bar.
7) press F8 to confirm changes,save and exit.
8) Enter into bios and set the boot controller order smart array controller as 1st.
9) press escape button and restart the server.
10) boot with cdrom and proceed for os installation.
6)
Jan 19, 2011 | HP Compaq ProLiant ML350 G3 Server
How to install windows xp in lenovo G460
if you have the windows XP disc. put it inside the cdrom drive then restart the computer. keep on tapping the F12 key once the computer is restarting. you will be rprompted with boot options. select your CDrom drive as boot device then hit enter. your computer should boot now using the cdrom. XP installation should be running now.
May 07, 2010 | Computers & Internet
Unkown SCSI Problem
Hi Fatoil ,
Have you tried another SCSI port , another SCSI card , another SCSI drive , swopping if it is card problem or drive or both problem ?.
If you have a spare SCSI hd , plug it in to same port and see if it works . Swop to another port and see if the spare SCSI hd works. Swop to another SCSI card and see if spare SCSI hd works.
All this elimination will narrow down the problem .
SCSI cards are not expensive ,.
old working SCSI hds don't cost you anything if you have them.
Sending out the server for servicing will cost you.
I presume you don't have a maintenance contract for this server .
If you have , get them down to settle it .
If you don't , after you settle this matter , make sure you get a maintenance contract for all your critical servers / equipment.
Maint Contracts seem expensive when nothing breaks down. However , when they do , it makes every worry go away.
Good luck,
David
May 26, 2008 | HP CC3310 (a9863a) Server
Booting up to windows or cdrom
please try to boot with window server 2003 Cd .If that boot from server then error is with the OS which you installed
Dec 26, 2007 | AOpen AK77-600n Motherboard
PowerEdge 2600 does not boot up ?
you need to set the boot device order. Usually F12.
or you can go to bios with F2 or F10.
your cd-rom is wrong you need the Instalation and Server Management CD. I think it's possible to download this cd at their site.
good luck
Dec 03, 2007 | Dell PowerEdge 2600 Server
CDROM and with a bootable CD is not been detected
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Nov 29, 2007 | Dell PowerEdge 2600 Server
Compaq ProLiant ML530 Server Logo
319 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
