Question about Microsoft Windows XP Home with SP2 N09-00984-os for PC
\\192.168.1.27 is not accessible you might not
\192.168.1.27 is not accessible you might not have permission use this network resource contact the administrator of this server to find out if you have access permission
Access is denied
  • nettechnick May 11, 2010
    Are you trying to connect to another PC or network enabled printer?
  • Jeff S May 11, 2010
    What device is supposed to be at 192.168.1.27?
    Problem Solver:
  • 11 Answers
1- Make sure that these services are running on both systems :
Computer Browser
Server
Workstation
2- Make sure that both PCs are configured to be on the same network IP address
3- Make sure that firewalls are not blocking the traffic bettween these 2 PCs
Posted on Feb 03, 2010
2 Suggested Answers
fidoliedo
  • 162 Answers
SOURCE: access is denied
Is this on a domain?
Posted on Jul 25, 2008
Tip
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Computers & Internet
The folders for the iomega storage drive no longer are displayed on my computer, and when opening up my network it shows the folders listed there but gives the error, "\\Network storage\public is not...
Make sure you are logged in as the Administrator of your computer. Power cycle (turn it off and back on) the device. If that doesn't fix the problem. Try factory resetting the unit (depress the reset button on the back of the unit for 4-5 seconds).
Dec 14, 2010 | Iomega 1TB Home Media Network Hard Drive...
Can you help me. I have a remote stores with DSL and FIOS connections. The connect back to the corporate office via a VPN connection using a CISCO ASA. At one point I could get on the internet and...
the issue is that you probably do not have a host or administrator right ...and this is required ...also when you accessed it wasn't firewall ed ...now ...in order to access it by its IP from the browser you need to disable the firewall or to insert your computer into the allow exceptions in that firewall on the remote machine...
Nov 04, 2009 | FixYa Computers & Internet
I can no longer access any of my files on my wd1tb network drive
It sounds like either the NAS enclosure or the drive(s) inside have failed.
If the enclosure has failed and you don't have any crucial files on it that you don't already have elsewhere, contact www.westerndigital.com for a warranty replacement.
If the enclosure has failed and you DO have important files on it, try having your local PC shop move the hard drive(s) into a new enclosure, if that works you're done, buy the new enclosure.
If the new enclosure fails, your drive is damaged and you will need a pro to help get back your files. If this is the case, reply back with you location(Country, State and City) and I will pass along recommendations for your neck of the woods.
Hope this helps FixYa,
Chris
Oct 24, 2009 | Western Digital MyBook Studio 1 TB USB...
I have created a workgroup on 2 PC's called MSHOME.XP Home Pn one PC I can access the workgroup fine. On the other when I try to access the workgroup I get an error MSHOME is not accessible. You may not...
do this to the other pc that cant access to your workgroup..
1. right click My Computer
2. click properties
3. click Computer Name
4. click the button Network ID, from here read carefully the instructions then the pc will ask you to make a restart after you correctly configure your network settings..
hope this will help..
Dec 17, 2008 | Computers & Internet
Networking problem
Make it sure if the user you used in the laptop is administrator right because you need the administrator right to access some network computer. check also if the desktop share folder is share with full access it maybe the right is read only.
Apr 23, 2008 | Dell Inspiron XPS M140 Notebook
Can't access my share folders
Drive management show only safely remove usb drive.
When u use mionet software it map the share to a drive letter. If u create folder or files on that drive u dont have permission to chance those files or folders on \\mybookworld.
Solution, dont use mionet software.
Nov 12, 2007 | Western Digital 500GB My Book World...
Microsoft Windows XP Home with SP2 N09-00984-os for PC Logo
369 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
