Question about Cobra 29 LTD CB Radio
It blows fuses when u plug the power cord up - Cobra 29 LTD CB Radio
  • Jim Anderson
    Jim Anderson May 11, 2010
    Can you tell me if the radio is used or new? Has it been uh...modified in any way? -Jeeem-
  • 56 Answers
The radio was probably wired backwards at some point. There is a reverse polarity diode inside that must be replaced to fix this. If you have continued replacing fuses and plugging it back in, there may be further damage such as finals or audio amplifier chip as well. you will need to take the radio to a qualified repairman for service. If it is simply the reverse polarity diode, your bill should not be more than an hour's labor charge.
Posted on Feb 12, 2010
For some reason , my microwave keeps blowing the fuse. Every-time I plug it in , it sparks and blows the fuse/trips the breaker. I dont think its the door switch because it has nothing to do with being...
Your unit is drawing way too much power, especially before you even activate the heater & fan modules. Could be dozens of causes. First line of defense is to check the power cord for a short. Consider your expertise and unit's warranty before opening it up. Check, trace and/or replace the cord. Don't ignore radiation exposure warnings, some shields are critical.
Oct 08, 2013 | Microwave Ovens
Fuse Blows
does the unit works at all?
Dec 11, 2007 | Lowrance Iway 500c GPS Receiver
My 2006 VW Beetle continuously blows the Accessory fuse utilized for the power port for the cigarette lighter and underneath the center console. The proper fuse was replaced. Only my phone plugged in when...
Hi Troy,
Without seeing the ports of the car and the plug of your charger, it would be difficult to diagnose with any certainty. I do have a suggestion however. Your note suggests that other devices do not cause the fuse to blow when they are used - it is only the charger for the phone. Since the charger works in other cars, it is probably not an overload condition due to a defective charger, but more likely a mismatched set of contacts between the plug and power port in your car when the two are mated. Some cars have slightly different sized power ports that can be either too tight or too loose for some plugs. Too tight ports could be causing parts internal to the charger's plug or car's power port to short together and blow the fuse.
We can get around this be using a different plug. The easiest way is to find a cord set that will plug into your car's power port and provides a simple extension for 1, 2 or 3 outlets. These can be found in auto parts stores and the automotive departments of stores like K-Mart, Sears, etc. Some examples look like these:
Insert the plug into the power port - and check that the fuse does not blow by checking the fuse - not by plugging something into the the outlet on the cord. If the fuse remains good, then it is safe to assume that the problem with your charger and the car's power port has been eliminated, and the car's power is available at each of the outlets of the new cord.
Try plugging the charger into the outlet of the new cord. If all is well, the charger should be working as expected. What we have done is removed the charger / car power port combination from the equation, by providing a different combination to do the same thing - but without the same physical connection that causes the fuse to blow.
You could achieve the same results by changing the charger plug under the right conditions - but many chargers now a days have circuitry inside them that change the car's 12 volts to something different. If you can find the voltage out of the charger and are able to match it with another - it must be the same voltage, polarity, current and phone power connector of course - it should work, too. You must be absolutely sure of the power requirements and your rewiring - if not, stick with the addition of a cord described above.
I hope this helps & good luck!
Aug 27, 2012 | 2000 Volkswagen Beetle
Plugged in cord, and computer went black
Remove the main battery and power up, if no change! have the power supply tested, if okay! sub out the ram memory one at a time and test, if no! the DC jack in the laptop do cause issues, at this level I recommend a tecnnician to get to the bottom of this.
Apr 04, 2012 | Toshiba Satellite M645-S4061 Notebook
I have a 29 ltd with no mods that i know of .i installed it into my 2006 nissan titan and when i plug my power cord into the unit it instantly blows the inline fuse. i have a 3 amp fuse in it . do you...
  • Well it could be. Did the CB work before putting it into your truck? If the fuse is blowing you have a direct short. You might pull them two little screws on the tip of the cord and inspect the wires and tips of the cord. Make sure everything looks good there. Make sure the cord is hooked up properly as well.
  • Let me know what you find out.
  • Hope this helps.
Nov 19, 2011 | Cobra 29 LTD CB Radio
Whistler 1730 keeps blowing fuses. no other problems with cigarette lighter plug
Is the lighter socket fuse blowing or the fuse in the unit's power cord? Have you tried another power cord from a Friends radar detector? If it doesn't blow that power cord's fuse, then your power cord is bad. If it does blow the fuse in the other power cord, there could be something wrong with the unit. Contact Whistler at info@whistlergroup.com
Jun 15, 2011 | DE-1730 Radar Detector
200/400 watt Powerline Dc to AC Inverter blows fuses
If the inverter is blowing the fuse immediately upon plugging in the inverter (before you even plug something into the inverter) you most likely have a short in the 12V power cord. If you have an Ohm meter, you should be able to check the resistance across the two contacts on the 12V plug of the power cord. Wiggle it around some. If you get a very low reading, and especially if it's intermittent, you have a bad cord, which should be pretty easy and cheap to replace. My experience with these cords has been that their quality is pretty poor.
If that is the problem, maybe you can cannibalize a cord from an old CB radio, but here's a fairly heavy duty one on Amazon (they don't give an amp rating though) http://www.amazon.com/Truckspec-TSPSCBH-2CP-12-Volt-Platinum-Replacement/dp/B001JT5QF0
Feb 23, 2010 | Powerline 0900-73 Slimline Inverter
Won't switch on
yes it could be a fuse but moust of the time
the fuse is blowing because power suger/or bad flyback/hozoutput/or power supply whent bad. unplug the tv .take off the back and look for the fuse you see the power cord it by the powercord if the fuse is black it a hard blow.
if you can see thur it .it a sofe blow you can try to chang it.6.1amp fuse125v or it could be 250v fuse6.1amp and if the fuse blow agon you have a short powersupply
Jun 02, 2009 | Televison & Video
Cobra 29 LTD CB Radio Logo
129 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
