Question about AOpen MX46-533V (91.89U10.061) Motherboard
My Mother board is Stuck on Detecting IDE Drives...
HELP!~~ sometimes its stuck there
Check ur IDE cable or ur device/Hard Disk/CD-Rom..
Posted on Feb 19, 2008
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
Can't enter window
check you cables from drives to mother board make sure they are all pushed in tight
and check the jumpers are set properly on all your drives then retry if it deosn't work you might need new motherboard or one o your cd or hard drives is faulty
Jul 09, 2010 | Gigabyte GA-K8VM800M Motherboard
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
Cant boot up gateway gt5628
pull the battery off the mother board for a couple days to reset the bios
Mar 08, 2010 | Gateway (4000444) Motherboard
My computer has problem HDD can not detect.mother board ASUS P4VP-MX, how to solve the problem, thx
Please remove the IDE cable from Hard drive and from HDD controller ,re-connect the cable with HDD and HDD controller.If still not resolved then connect with another IDE cable and check it .if not resolved then check with another HDD controller and check in the BIOS its detecting or not .If not then issue that Hard drive is faulty might be logic card .its better call vendor for repair it.
Nov 19, 2009 | Computers & Internet
Hard disk Not Detecting (Media Problem)
may be comming steps you solve your problem
check your bios settings on first bootable devices
check your ide or sata cable interfacing mother board correctly
check the power connections
also you want check this one is your os faulty,now you make master &sleve and boot anther hard drive
Jun 12, 2009 | Kanguru - 500GB Disk (Black)...
Problem getting hard drives to run
check the power supply. some time power supply not suppling the proper voltage to the accessories.
Nov 26, 2008 | Intel Motherboard
Unable to use SATA hard disk with existing IDE Hard disk
Hi abhinav13, please disconnect you're IDE. (do not remove it).
You're board only supports SATA 1.0 which is 1.5BG & not the SATA II at 3.0GB. Knowing that you may need to use the jumper to set the drive to 1.5GB. Once you are sure the drive is set correctly than hook it into the PC. If after disconnecting the IDE & SATA drive is shown in the bios. Set the jumper on you're IDE to function as a slave drive.
Enter the bios again. If you do not find the SATA drive listed than your onboard SATA controller is defective. You can not fix that.
So hate giving out bad news.
Luck!
Mike
Apr 09, 2008 | MSI K8MM-V Motherboard
530cmt
Before you go to switch any drive to master, look over you optical drives and other hard drives to make sure they are not set on Cable Select with the jumpers on the back of them. If you have 2 optical drives, set one to master and one to slave, same with you hard drives. If you only have one optical drive then set it to master. The jumper layouts are on the big label stuck to the top of the drive.
After setting the jumpers on them you need to install them. Both IDE cables you have 3 plugs. One connects to the mother board, another to the slave and another to the master. Connect them to their corresponding drives.
Feb 22, 2008 | HP Compaq d530c PC Desktop
AOpen MX46-533V (91.89U10.061) Motherboard Logo
76 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
