Question about Canon PIXMA MP160 All-In-One InkJet Printer
Every time i start it it flashes E,3 and the alarm light turns on
  • Canon Master
  • 511 Answers
E3 mean ink out. Push and hold reset button for 12 minutes. It will release ink level counter.
Posted on Feb 02, 2010
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Security light flashes and it won't start
top
CODE ALARM SYSTEM
information is always subject to change and correction Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm only Press the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter “UNLOCK” button once OR turn the ignition switch to the “ON” position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
top
Jul 10, 2008 | 1996 Subaru Legacy
The turn signal lights flash 3 times on my 2004 softail. what code is that indicating?
Three times turns on the alarm but you stil be able to move the bike without the alarm going off ,like when you on a ferry or train
May 16, 2012 | 2004 Harley Davidson FXST - FXSTI Softail...
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Security light flash no security system on truck
sometimes turning the ignition on 3 times quickly without starting will reset the computer. If the van has power locks and keyless entry then try using only the keyless entry. Sometimes your car wont have a alarm but an anti theft device which will not allow it to start if it goes off or something triggers it.
Jul 26, 2009 | 2003 Dodge Ram Maxi
2005 Hummer H2 battery went down and when I replaced it the alarm keeps going off and it will not start.
if it is the factory alarm you will have to do a relearn. G.M. uses a couple different ways to do the relearn and I would think it would be the same for hummer. turn off all acc and then turn the key to the on position wait 10 minutes you will see the light on the dash flash and go out . asap turn the key to off to on 3 times quickly and the third time leave it on on again do this 3 times for 30 minutes then after the final turning of the key 3 times on the 4th time start the car. so turn off all acc like radio , a/c ect then turn key to on in 10 minutes the light on dash will flash and go out quickly turn key from off to on 3 times and once again leave on on do that 3x for 30 minutes then start the car. that is the gm relearn for security they have one on some models that start after 10 minutes but that is usualy on the cheaper cars so just do the 30 minute.
Jun 04, 2009 | 2006 Hummer H3
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
130 people viewed this question
old marine
old marine
